Browse Forums Home Theatre & Automation Re: question on hiding cables behind plasterboard wall 3Sep 21, 2008 3:29 pm jarthel what if there is a noggin in between the stud? what are my options? thank you very much if the noggin is half way down the wall, u may have to cut the gyprock, then the noggin, otherwise you need a drill thats 1.5m long !! Re: question on hiding cables behind plasterboard wall 4Sep 22, 2008 12:14 pm jarthel,
generally there is a gap between the noggin and the plaster but if this is not the case we used to use a drill bit that was 3 metres long. (1 metre sections) to get down inside walls! Contact rod for this service. Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7945 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2578 Plasterboard Gyprock is very popular as a reveal liner these days. You need to provide a way of supporting it, we use a modified timber reveal or bracket. You will be… 1 4764 |
