Browse Forums Home Theatre & Automation 1 Sep 16, 2008 11:31 pm 23in to 37in (PLB103S): http://www.selbyacoustics.com.au/storef ... =240736593
40in to 63in (PLB103B): http://www.selbyacoustics.com.au/storef ... =240723719 =========== I currently have PLB103B. My wife has said that it seems the 50in too big for the lounge so I'll be moving it on the rumpus room (which will become sort of HT room) once she buys a replacement TV. In the possibility that she buys a 37in (or smaller) TV, do the bolts that come with PLB103B the same size as the ones that come with PLB103S? I asked since I can easily mount the smaller bracket when the time comes. Thank you very much Re: question on mounting brackets as sold by Selby 2Sep 16, 2008 11:46 pm Hi Jarthel,
The brackets and the supplies that come with them are exactly the same. The only difference is the 103s is smaller in width. Bear in mind also that the 103s will not span 2 - 600m studs so mounting it in he same position wont really work. You may be better to keep the 103b on the wall where it is and buy a new 103b for the theatre room. Re: question on mounting brackets as sold by Selby 4Sep 16, 2008 11:57 pm kinda easy when you sell them all day long!! Old Home Restoration / Renovation Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look… 2 3295 Building Standards; Getting It Right! When my house was built (over 7 years ago), the post brackets were done to allow for concrete porch, but they didn’t allow for the planned stone paving. I’m finally… 0 1929 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5893 |
