Browse Forums Home Theatre & Automation Re: Ceiling speaker in kitchen? 5Sep 17, 2008 9:57 am I moved this thread over here...
In-Ceiling speakers in the kitchen are not a bad idea, or in any room really, if you enjoy listening to background music while doing whatever you do in that room (eg. listening to the radio while cooking...). With In-Ceiling or In-Wall speakers at least they are out of the way - not taking up any floor/bench space - and often not seen (or at least noticed) at all. You then also have a choice as to how intrusive, or not, the components that drive and control these speakers are. For In-Ceiling or In-Wall speakers, if you can, you should get the speaker wire installed during frame stage of construction, but the rest should be no difficult after you move in. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5936 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2452 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17198 |
