Browse Forums Home Theatre & Automation 1 Sep 02, 2008 5:40 pm Hi there gurus - sorry to bringing up this thread again but just got an email reply from SAMSUNG tech support team re installing p/point & antenna socket behind a plasma tv.
This was my questoin to them: .....We want to hang it on a wall but need to know whether it is safe to locate the powerpoint & antenna socket on the wall directly behind the TV or at floor level, with concealed cabling in the wall cavity. Samsung's response : What you are suggesting is fine, just ensure you don't hardwire the TV somehow so that if it ever needed unplugging, you could not unplugg it, other than that, powerpoint and RF point behind the unit or floor level concealed poses no operation problems to the unit Can I assume then that it's OK to install the p/p & antenna outlet behind the tv? I'm confused. Don't want to do the wrong thing, but installation directly behind the tv would be the best option for us. What do you think ? Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Plasma installation 2Sep 03, 2008 9:35 am Yes you can.
Their concern is if the power point itself is concealed (ie inside something you can't access (wall, anything) or behind something you can't access) then you will have difficulty unplugging it etc. if the need arose. I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5375 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6371 |
