Home theatre cabling and security cabling
We are building a double story home thinking to have home theatre cabling and security cabling under construction
Can some one give me any ideas what things need to be done for home theatre and other cabling in house
Any other ideas which things are important to be done while house is under construction
Thanks
Projector and screen wiring.
Considerations for main equipment area -- if you have linen cupboard close by, it would look much neater and cleaner to put stuff in there.
Think about what equipment you will have and put in as many PP as you need -- avoid use of ugly power board.
Home Theatre
Although 7.1 or .2 is great. if the room is between 5 to 7m of length I would stick to 5.1.
Rooms above 8 metres by all means 7.1 but you will be wasting money on the 7 speaker wiring.
If you can prewire yourself get a couple of rolls of cable and wall plates and do it yourself.
With my build my builder has to do it as they do wiring inhouse.
Alarm System
Consider an alarm system to be done also either prewire or the full install.
Surveillance System
In my case I am getting an 8ch pre wire cat6 cabling done and will do the cameras/NVR/DVR myself.
the 5.1 wiring is $1140 times two as I am doing two rooms in 5.1.
Alarms system with 8 pir's just over 2k. (IP capable and touchscreen)
Thanks
2
It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and…
23/05/2023
1
It seems very clear to me that your contract states that a security account does NOT need to be established so the answer to the builder is NO. If in doubt find a contract…
21/10/2023
Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the…
