Browse Forums Home Theatre & Automation 1 Mar 01, 2017 9:04 pm Hi all im about to move into my new home in the Willowdale estate, its a nbn ready area and the house has a NBNCo box in the garage . My house came with x2 data points as standard inclusions.... As the house was already under construction when i bought it i wasnt able to ad extra data points to the 2nd floor. My question is how many data points can a setup like this take before i need to upgrade hardware? Any info is appreciated I said after the 1st build “ never again “ & now im on my 3rd Re: NBNCo new house data points 2Mar 04, 2017 9:57 am You could connect a switch to one of the data point, then from there extend out your network using wifi. Another option would be to use Ethernet over Power adapters. They come in pairs, so connect one end into the powerpoint (same room as above switch) and use one of the switch port. Then connect the other adapter into the powerpoint where you want the data to come out. If you want more ports where this comes out then add a switch. Not the neatest solution but will get you data upstairs easily. I'm currently using the below in an old house and it's working pretty well. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13897 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20734 Yes well there solution is to blame everyone else while I a 65yr old woman with major medical problems have to just continue to boil water and wash myself in a bucket… 2 16062 |
