Browse Forums Home Theatre & Automation 1 Jul 25, 2008 2:55 pm Is there anything around that will allow me to control devices that are plugged in at home from a remote computer?
For example, if I was out and wanted to turn on a light or electric blanket etc is there a gadget that I can plug these devices into that I can then control from any remote computer? I should add that I am looking for a cheap and not super high tech options here Re: Home Automation - Control via PC? 2Jul 26, 2008 3:52 am Hi McReidy
The X10 system might be the way to go... It runs over the power lines, but there are also wireless options available. Here are some stockists and sites that may help: [url]campad.com.au[/url] http://www.whomedigital.com.au http://www.iqhome.com.au Cheers! After 2 false starts, a year living overseas, two more world trips and 3 years of uncertainty we are now starting the build process again - hopefully for real this time! Re: Home Automation - Control via PC? 3Jul 28, 2008 5:08 pm Mythtv also provides a lot of opensourced linux software to do this sort of thing with x10 as well as many others.
There was an article recently about a guy who used linux to control everything..i can't seem to find it but he even injected a microchip in his arm for full automation..how cool(bizzar) is that! Re: Home Automation - Control via PC? 4Sep 25, 2008 8:43 pm There are several home automation technologies out there depending on the requirements - many have different cabling requirements. I would recommend DIY kits. They've got a bunch of wireless and hardwired DIY kits that can be used with their inexpensive monitoring service. For a small to medium-sized townhome, a wireless kit may be good for you.
A very good option would be a company called Mile High Automation. I have installed an integrated system called Home Automation Platinum Package: Whole-House Solution. It's got: * Omni Pro II Home Automation Controller * 1 Touch Screen * 2 LCD Keypads * 6-Zones of Audio * 17 Automated Light Switches * 20 Security Contacts * 2 Thermostats * Computer Control Software * Complete Programming & Support You can start with just the alarm system and grow it to a fully functional home automation system. You can also submit your floor plan and can get free estimate plan to implement DIY systems in your home. For Home Automation Product and services- Dream System Free Home Automation Estimate Cheers James. James Nicholes Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28812 To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9858 Hi group, have some damage to the door frame and skirting board. It's a side door to the laundry area. Only has a security door. I had a termite inspection (note drill… 0 5054 |
