Browse Forums Home Theatre & Automation Re: Pre cable wiring for Home Theatre System 2Jul 27, 2015 2:25 pm For speakers don't go thinner than 16 gauge, go thicker if possible. Lay the hdmi And make sure it's compliant with the latest tech requirements. Don't forget a gpo in the ceiling for the projector. As for best cable I will let you decide whether to buy-in to the various arguments Re: Pre cable wiring for Home Theatre System 4Jul 28, 2015 2:51 am Kyle9600 if like me your theater is on the ground floor then it is massively more convenient to pre lay. Of course it can be done later but it would be more stressful. Re: Pre cable wiring for Home Theatre System 6Aug 01, 2015 12:57 am GPO General Power Outlet or power point to plug the projector in. If the projector set up is in the garage then it may be quite easy to do the wiring after. Depends if the garage is having finished ceilings and you want the wired chased into the walls. We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16278 We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13758 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8707 |
