Browse Forums Home Theatre & Automation Re: NBN Enclosure ... Have any one done this . 3Jul 24, 2015 2:37 pm Please do post a little more than a picture - it's hard for people to assist if you don't give some context. Also try to post in the correct sub-forum. Moved topic to correct forum. Completed a knock down and rebuild in northern Melbourne. Handover completed 27/09/2013 and now moved in. Re: NBN Enclosure ... Have any one done this . 4Jul 26, 2015 2:30 pm Where would you like to install this? In a garage, cupboard or somewhere else? 'It's not the size of the dog in the fight, it's the size of the fight in the dog.' Re: NBN Enclosure ... Have any one done this . 6Jul 27, 2015 8:38 pm jomesh007 Garage How much is this enclosure and where are you buying it from. I like the idea however does heat play a part in this if the NBN components get hot? 'It's not the size of the dog in the fight, it's the size of the fight in the dog.' Re: NBN Enclosure ... Have any one done this . 7Jul 27, 2015 9:25 pm Handy007 jomesh007 Garage How much is this enclosure and where are you buying it from. I like the idea however does heat play a part in this if the NBN components get hot? The item in the bottom right is a UPS or battery back up. The item in the top right is a device that converts Fiber to copper. It then runs to the termination points which in turn should run to the switch on the left. I would suggest contacting a licenced data cabler. Re: NBN Enclosure ... Have any one done this . 8Aug 01, 2015 8:29 pm Gunna Handy007 jomesh007 The item in the top right is a device that converts Fiber to copper. It then runs to the termination points which in turn should run to the switch on the left. I would suggest contacting a licenced data cabler. Not quite. Top right is a fibre termination socket. Both sides are fibre, it then goes into the NBN box, called the NTD in the middle which 'converts' fibre to copper. Actually it does a lot more than that, but keep it simple. Anyway from here on it is the customers equipment, which could be into a switch, wifi router etc, neither of which need to be installed in this cabinet. Note these days they don't do the fibre termination socket, instead they come in behing the NTD and terminate the fibre direct. Re: NBN Enclosure ... Have any one done this . 11Aug 06, 2015 6:09 pm The enclosure is exactly the same as the pic u posted including location of the switch Re: NBN Enclosure ... Have any one done this . 14Aug 10, 2015 11:21 pm No point, the NTD does not need to take up space in any sort of enclosure unless you are doing it for the looks. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 34180 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 9136 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 12141 |
