Browse Forums Home Theatre & Automation 1 Jan 14, 2015 12:47 pm How has everyone else gone about wiring up a theatre room? I am looking at wall mounting a TV, so need cables in the wall to run from the floating shelf to the TV. Also need the ability to run cables to the rear speakers (preferably not along the ground). Considering I am doing this on a single brick wall, and the other site of the wall is the ensuite (ie plumbing in the wall) I would rather not do it post build, but running umpteen bits of conduit and cables is costly. Hoping to get some hints/tips from others here. Follow my build here: viewtopic.php?f=31&t=74975 Re: Home Theatre Wiring 2Jan 17, 2015 7:19 pm While there are many different ways to do it, generally when mounting TV's on walls, you will conceal your cables with conduits that are placed inside the wall during build. You need to size your conduits appropriately for the amount of cables you need to run to your TV and also allow for future expandability. For running speaker cabling to your surround speakers you will have a conduit leading all the way upto your roofspace, in some cases you may need to chase the wall at the required area to where your speakers will be mounted. For running speaker cabling to front stereo speakers if they are going to be significantly further from the entertainment unit, you get the wall chased out horizontally to run the speaker cabling. If you have a contractor who is taking care of all your smart wiring installation, they would also be able to do your home theatre installation. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16253 From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some… 2 10621 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110533 |
