Browse Forums Home Theatre & Automation 1 Dec 27, 2014 9:50 pm Just wondering after 3 yrs of constant problems with our fibre iprimus finally sent someone out to look in our fibre cabinet and it was decided the best thing to do was smartwire house/cabinet. Since they did smart wiring internet has been fine but now i cant access any net through foxtel such as catch up services why is this the case when all other ports in house access net fine and the foxtel port worked fine before smart wiring was done? Re: foxtel and smart wiring 2Dec 28, 2014 12:11 am Hi Techno74 Do you have a LAN tester, it could be that the mech is wired differently one end to the other. or the punch down tool for the mech's has not correctly terminated it. _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: foxtel and smart wiring 3Dec 28, 2014 9:05 pm All i know is we had modem in fibre cabinet but now its changed to modem in house and net loops back to all ports/outlets in house which we have about 10 and they are all picking up net except the one my foxtel box is plugged into. Re: foxtel and smart wiring 5Dec 29, 2014 1:32 am Yes I believe it is a wiring issue, nothing major just have to check colours on mechs at both ends. As mentioned above, yes by plugging in a patch lead to the wall mech then to the laptop if no connection then I would say it is wiring issue. Is the mech labelled at both ends? If so is it patched from switch/internet modem? _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: foxtel and smart wiring 6Jan 17, 2015 7:26 pm This can be a cabling fault or equipment fault. There is a Mech at the wallplate and generally there will be a patch panel inside the Hub, the fault can Lie anywhere at both ends and in between as-well as with the equipment that is connected to on both sides. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16290 Shelly switches require a paid subscription for full access to all features which is ridiulous given the lifespan of a home and if you were to sell it or buy a home with… 2 4545 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10051 |
