Browse Forums Home Theatre & Automation 1 Nov 03, 2014 8:13 pm Hello Guys, A quick question and any tips/advise is much appreciated for the home theatre wiring builder is charging us the following 1. Pre-wire for 5.1 Home Theatre with with an additional 2 speakers in the outdoor leisure -1315.00 2. Pre-wire for 5 Sonos Audio zones - 660.00 seems very expensive to me. is that reasonable? Can we do after the handover? how easy/costly to do after the handover? please advise me. I need it urgent cheers Re: Home Theatre - wiring requirement - please 2Nov 03, 2014 8:28 pm Depends on what wire is being used and how long the runs are. Re: Home Theatre - wiring requirement - please 3Nov 03, 2014 8:48 pm Thanks Aussiemark. the following in detail. 45 metres Liberty 14AWG low loss oxygen free 4 core speaker cable 1 x 8m Audioquest HDMI cable 10m Krone Cat6 Data cable 100 metres Liberty 16AWG low loss oxygen free 4 core speaker cable Re: Home Theatre - wiring requirement - please 4Nov 04, 2014 10:32 am anup 2. Pre-wire for 5 Sonos Audio zones - 660.00 Unless your plan for your Sonos audio zones are of the Amp variety, where you might install the amp in the ceiling and have speakers mounted through the ceiling, that sounds extraordinarily high to me. If you are using the Sonos Play x units, then you just need 240v access to them. So that works out to $132 each Sonos unit. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Home Theatre - wiring requirement - please 5Nov 08, 2014 7:02 am Thanks bpratt, But can I do the HDMI and spaker cable after the handover? How easy? Or even I hire a electrician can do it without breaking Is it easy to do now? How hard to wire those cable after the handover? Re: Home Theatre - wiring requirement - please 6Nov 23, 2014 2:20 am We are unable to predict what sort of house you have so cannot answer those questions. The short answer is that you will have the least troubles and possibility of damage to the home if cabling is done during build rather than after the build. You are best off to talk to an electrician or cabler for advice. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15767 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16275 Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the… 0 8568 |
