Browse Forums Home Theatre & Automation Re: cabling plan 21Feb 23, 2015 9:23 am Running network cables is supposed to be done by a licenced cabler, and if people want to be sure everything properly certified, then you will have to pay the dollars for it. Of course, if you do have some knowledge in cabling and have the confidence to do so, even though you may not be licenced there should be no huge issue in doing it yourself. At the very least most people can run some cat6 (or similar) cable throughout their home whilst being built, subject to their builder allowing them to do so... don't run this cable right alongside with your 230v cabling though! Once cabled, you can then get your licenced cabler in to terminate the cables pre-laid. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: cabling plan 22Feb 23, 2015 10:10 am bpratt At the very least most people can run some cat6 (or similar) cable throughout their home whilst being built, subject to their builder allowing them to do so... don't run this cable right alongside with your 230v cabling though! Once cabled, you can then get your licenced cabler in to terminate the cables pre-laid. Whilst I agree with you and others on this thread that running in a bit of cat6 is not rocket science, and as long as someone keeps it away from power and doesn't kink the cat6 cable, it should turn out ok. But it's still illegal, and I can't endorse or encourage anyone to do it. Even running in the cables and having a licenced cabler terminate them is not legal, strictly speaking, and unless he is your best mate, I doubt any licenced cabler would risk his licence by terminating cabling that he can't see and didn't install. Do it at your own risk, but don't complain if it doesn't work properly or if you get fined. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: cabling plan 23Feb 23, 2015 7:29 pm +1 to that. You're quite correct technically it is illegal and few licenced cablers will sign off on hidden cables, as he doesn't know what you've done behind all of that gyprock... for all he knows you may have taped all the cat6 to the TPS all the way through. However if the cabler is your best mate, chances are he'll start you off, and point out a few key things you need to ensure you do... a stranger won't tell you anything, and that then becomes your risk alone. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: cabling plan 24Feb 23, 2015 8:26 pm I rang our electrical consultant today and they were happy to add 4 more data points for us. Price per data point was $96.50 fully installed during the build process. We decided to throw one in each bedroom (5), one in the upstairs lounge, one in the downstairs lounge and one in the downstairs study, so 8 all together plus our hills hub in the garage. We have a relatively small house, so we don't have media room or rumpus but if we did, we'd throw one in each too. Got to think that it's not just PCs and laptops connecting to them but smart TVs etc as well. Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: cabling plan 25Feb 23, 2015 8:59 pm I have four data outlets behind our main TV. These things all have ethernet capabilities: - Smart TV - Blu-ray player - Playstation - X Box - Wii - Internet radio - Media server/hard drive I only have a smart TV, blu ray player and media server but who knows what else will come along Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: cabling plan 26Feb 23, 2015 9:11 pm 1960sModernistHome I have four data outlets behind our main TV. These things all have ethernet capabilities: - Smart TV - Blu-ray player - Playstation - X Box - Wii - Internet radio - Media server/hard drive I only have a smart TV, blu ray player and media server but who knows what else will come along Could you not have a router plugged into the data point that then splits the ethernet between them all? Just curious if that's an option for us? Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: cabling plan 27Feb 23, 2015 9:14 pm You could, but the data is aggregated between the devices, which might work ok given that it's unlikely that you'd have more than one or two devices running at the same time. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: cabling plan 28Feb 23, 2015 9:52 pm 1960sModernistHome You could, but the data is aggregated between the devices, which might work ok given that it's unlikely that you'd have more than one or two devices running at the same time. Yup, definitely sounds like a workable solution in our case. We generally only have a max of two devices going in each location currently and that's not going to change.. we don't actually own a smart TV and use other devices to do all the "smart" stuff anyway, so I think it will be fine Paddington 29 @ Blue Horizon Estate (Lot 105, Wattleridge Crescent, North Kellyville) Our Build Progress Blog: http://light487.wordpress.com/ Re: cabling plan 29Feb 24, 2015 8:02 am You would want a dumb switch not a router to still stay within layer 1 or 2. Some routers do switching, but most cheap ones don't. An 8 port GB dumb switch is very cheap. I have single points to each room from my main router and switch area and then a dumb switch in each of those rooms to distribute it to the devices. It's cheaper to buy a switch ~$30 than pay for an additional data port. ~$90. Re: cabling plan 30Feb 24, 2015 8:15 am shadowarrior You would want a dumb switch not a router to still stay within layer 1 or 2. Some routers do switching, but most cheap ones don't. An 8 port GB dumb switch is very cheap. I have single points to each room from my main router and switch area and then a dumb switch in each of those rooms to distribute it to the devices. It's cheaper to buy a switch ~$30 than pay for an additional data port. ~$90. Can you please link to an example switch? I had a very, very quick look last night and found 5 and 8 port giga switches but they were $80+ Re: cabling plan 31Feb 24, 2015 8:30 am light487 shadowarrior You would want a dumb switch not a router to still stay within layer 1 or 2. Some routers do switching, but most cheap ones don't. An 8 port GB dumb switch is very cheap. I have single points to each room from my main router and switch area and then a dumb switch in each of those rooms to distribute it to the devices. It's cheaper to buy a switch ~$30 than pay for an additional data port. ~$90. Can you please link to an example switch? I had a very, very quick look last night and found 5 and 8 port giga switches but they were $80+ 8 Port Gigabit Plastic TP-Link SG1008D http://www.tp-link.com.au/products/deta ... l=TL-SG108 $25 at MSY. Unless you want to manage the ports or have a small office setup, a dumb (unmanaged) switch is all a typical home network needs. Re: cabling plan 32Feb 24, 2015 8:46 am shadowarrior light487 shadowarrior You would want a dumb switch not a router to still stay within layer 1 or 2. Some routers do switching, but most cheap ones don't. An 8 port GB dumb switch is very cheap. I have single points to each room from my main router and switch area and then a dumb switch in each of those rooms to distribute it to the devices. It's cheaper to buy a switch ~$30 than pay for an additional data port. ~$90. Can you please link to an example switch? I had a very, very quick look last night and found 5 and 8 port giga switches but they were $80+ 8 Port Gigabit Plastic TP-Link SG1008D http://www.tp-link.com.au/products/deta ... l=TL-SG108 $25 at MSY. Unless you want to manage the ports or have a small office setup, a dumb (unmanaged) switch is all a typical home network needs. Thanks! i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17278 5 10476 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25163 |
