Browse Forums Home Theatre & Automation 1 Oct 02, 2014 9:33 pm Hi just wondering we have had no problems with receiving digital tv for 3 yrs until a few days ago we lost all signal to every tv in house (4 tvs) has anyone else had a problem? Am i right in saying if our tvs are digital ready we should still be getting them. We had all rooms fitted with tv port and im assuming it comes through fibre optic so who do i contact Re: digital tv problem 6Oct 03, 2014 8:26 am Silly question, but have you tried retuning your tv? The digital channels may have changed frequency Dale - Building Newbie Proserpine, QLD Re: digital tv problem 7Oct 03, 2014 8:35 am Sounds something like your signal splitter has failed or you have lost power to your fibre box inside the house/garage. Have you asked your neighbours who are on the same fibre system if they still have TV access there? If they don't chances are is there is an issue in the estate that needs to be taken further up. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: digital tv problem 9Oct 05, 2014 5:32 pm You most likely have an issue with your Fibre termination device aka the Box on your outside wall or in the garage, or if neighbours having a problem then its a problem with the distribution system in the estate. You will need to contact the provider of the service who may be able to get things checked out. If you urgently need to watch TV in the meantime, you can put an an antenna up on the roof and get it connected to your splitter. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV 2 5821 I don’t think so as the floor area over 300 square meters then it is class 3…. 12 17924 |
