https://forum.homeone.com.au/viewtopic.p ... c&start=15
you recommended the following bracket
Could I please get the details of the manufacturer and supplier, please?
Browse Forums Home Theatre & Automation 1 May 23, 2008 8:09 pm On the following post
https://forum.homeone.com.au/viewtopic.p ... c&start=15 you recommended the following bracket Could I please get the details of the manufacturer and supplier, please? mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Question on TV mount bracket..... 3May 23, 2008 8:48 pm Much appreciated Rod.... mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Question on TV mount bracket..... 4May 23, 2008 11:52 pm I know a bloke that works there
<------------------- If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8300 thank you! do we need to get this or our builder before we commence new build on the block? 2 10404 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9943 |
