Browse Forums Home Theatre & Automation 1 May 08, 2008 7:33 pm If you engage a builder to do Data (cat6), foxtel, tv and Audio cabling for 7.1. How would you expect the cabling to be terminated? Just got off the phone with the cabling sub who indicates they will only rough in and not terminate on the wall. Is this normal?
Scot Re: Finishing Data and Audio Cabling 2May 08, 2008 11:49 pm OK if they are professionals they will terminate the job correctly.
Whats the point of running cables that you cant a) terminate or b) use? I swear there are some lazy freaks out there. Re: Finishing Data and Audio Cabling 3May 09, 2008 7:54 pm They will rough it till the plasterer and painting done, but they should come back and terminate it and provide a certificate of compliance along with papers showing stats on errors on cat 6 etc.
It's part of standards. Steve Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20661 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7009 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13847 |
