Browse Forums Home Theatre & Automation Re: Post Build Fibre Cable Splitting / FTTH Query 12Jul 30, 2013 7:25 pm its Thanks.. explains everything.. One last query.. For Ethernet cabling I will need access to FTTH box for which I will need to ask Places Victoria But for splitting coax by a cabler and get additional wall plate put, will I need authorization from Places Victoria? Or can just get it done as I am not touching their FTTH box but just our internal wiring and wall plates?? I would assume that when you sign up for Internet access with an ISP they would arrange for the access you need to connect a router. As for the antenna coax, from your original post, didn't Places Victoria want a huge fee to connect additional coax outlets? (which makes no sense because their box should have a standard output level, so they should know how many outlets it will support, no need for "design"), so I would probably not tell them anything about it... DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 1813 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 1215 2 6314 |
