Browse Forums Home Theatre & Automation 1 May 11, 2013 10:01 pm Does anyone know if it is possible to re terminate (replace the end) of an optical cable? I have run one from my pc to amp through the at frame stage and now i have found one end damaged. and not working. I do have hdmi running from the pc as well but cant get the video card to through put the audio. Re: optical cable question 2May 11, 2013 10:48 pm See: http://www.youtube.com/watch?v=T_9l_-8PtaQ or search for something along the lines of "replace toslink optical cable connectors" Good luck! ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: optical cable question 3May 12, 2013 6:39 pm sceen7 Does anyone know if it is possible to re terminate (replace the end) of an optical cable? I have run one from my pc to amp through the at frame stage and now i have found one end damaged. and not working. I do have hdmi running from the pc as well but cant get the video card to through put the audio. look at your audio settings to ensure it is going out via hdmi Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 1 13125 |
