Browse Forums Home Theatre & Automation 1 Apr 30, 2013 3:13 pm Hi, I am looking to run the speakers cables for my home theater room. The problem is its a corner room, and the house frame is steel (JG King home) so not much space in the roof along the outside walls, I tried to get there and I couldnt reach, also the roof is colorbond. I did run cabling for my friends home, but that was a wood frame and tiled roof. So how can I run the cables ? Can I remove the screws of the colorbond and access the sides like we do with the tiled roofs? any idea's? Re: Running Speaker Cables For A Steel Frame 2May 01, 2013 7:24 am You can lift the roof sheet to gain access to the wall cavity. The other option is to cut a small hole in the plasterboard up near the cornice and then either push your wire up in to the roof space on a yellow tongue or drop a weighted string down from the roof space and grab it. You then need to patch and repaint the wall, so the roof sheet is the first thing to try. Re: Running Speaker Cables For A Steel Frame 3May 01, 2013 9:55 am Do you mean remove the screws on the roof top and lift the sheets? should i worry about leaks after i put the screws back? is it easy to lift the sheets? i can see the sheets are big coming from all the way from top. Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8023 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4458 |
