Browse Forums Home Theatre & Automation 1 Apr 17, 2013 12:12 am So my theatre is quite small, not the size perfect shape either but it is what I will have once the house is built and I was looking for some ideas on maximising on the space that I have in the room. Friends have told me that 7.1 would be wasted in such a small room and that I am better off going with a 5.1 setup, Mounting the wall on the Bottom wall as it backs onto a bedroom will mean that I am not shooting sound into my bedroom and annoying my wife. So the room is 3.8m x 3.3m I don't think I could viably put a projector in there so i will have to Wall Mount a 60 inch on the Wall. Do I need builders to put in extra support to support the wall mounting on a single brick wall? Additionally do you think I would benefit from any particular soundproofing or Wall Coverings? I appreciate any advice as im a little lost when it comes to all this. Shalquin. ----------------------------------------- TIMELINE: Land Deposit Paid: 25 March 2013 House Deposit Paid: 19 April 2013 Re: Small Theatre Room Ideas?!!?! :? 2Apr 17, 2013 2:57 pm Hi Shalquin, yes I would put a large LCD TV on the lower wall with a 5.1 system. 7.1 would be overkill for this room and wasted money spent. Get some extra noggins where the TV would mount for the bracket to screw into later on and also put some acoustic batts into all the walls in the room. As you have suggested a 60 inch screen will be perfect. Other than that get the speaker cables run during frame stage (2 at rear minimum) and other the cables FTA, HDMI, network all to where the TV would mount. Builder: Dennis Family Homes House: Hartley Facade: Provincial Suburb: Lyndhurst Moved in! http://cynash.blogspot.com Re: Small Theatre Room Ideas?!!?! :? 3Apr 17, 2013 7:11 pm my home theatre room is around 4m x 3.8m i think would need to measure again but i am going with similar to what asha has suggested i am having on the longest wall a cabinet in which the 60 inch tv will be installed the builder has put extra noggins to support the tv. we have asked for the electrician to install 2 ceiling speakers for us then these will be attached as part of the 5.1 system. i have also asked for extra double power points to be installed in the room so xbox dvd and other devices can be powered. i think all up on the wall of the cabinet where tv is there is 6 powerpoints and situated around the room another two double power points. i have received alot of info through the helpful members on this forum and also searching through the threads as i did not and still do not know much about setting up. i talked to the electrician also and he has placed cables in the wall ready for use. i have no windows in the theatre room and it is being used only as a theatre room . also the paint is very dark and also the ceiling will be painted the same as walls. on soundproofing do ask the builder to soundproof the room for you we also have ours soundproofed on all walls. as windowcovering i would use heavy curtains to stop light coming in . My house is still under construction but i think on friday the painters are painting the room and on the 30th april the carpets will be installed . i am also adding a ceiling fan to the room also do not know how far in construction you are but just an idea to give more room look at a sliding door or even a double sliding door to the room. Re: Small Theatre Room Ideas?!!?! :? 4Apr 17, 2013 8:10 pm 1rocky ....i think all up on the wall of the cabinet where tv is there is 6 powerpoints and situated around the room another two double power points. One question regarding all those power points, will you be using any surge protection on any of the electronic goodies? Whilst it seems like a good idea to have that many points I think 1 or 2 double’s with a surge protection power board to suit how many electronic devices you have may be a better way to go - just a thought..... ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Small Theatre Room Ideas?!!?! :? 5Apr 17, 2013 9:03 pm thanks pab yes will also be using surge protectors as well Re: Small Theatre Room Ideas?!!?! :? 6May 01, 2013 11:33 pm Who says you cant have a projector in a room that size? Of course you can and do it inexpensively too! (Cheaper than a big TV!) Have a look at the Benq W1080 Short throw 3D projector or the W1070 for only $989. Full HD, 1080P 3D that could do a 90" screen on your wall. Cheers, Matt Re: Small Theatre Room Ideas?!!?! :? 8May 02, 2013 1:37 am Yep agree with Matt..... I would look into a projector set up. If I were to go tv it would be bigger than 60 so that would make the projector set up a lot cheaper. Cost the options up, you would be surprised. Re: Small Theatre Room Ideas?!!?! :? 9May 02, 2013 1:19 pm How would you mount the Projector, would i need extra beams in the roof to support it? Obviously I would need a long hdmi cable running from the roof to the AV Receiver... ----------------------------------------- TIMELINE: Land Deposit Paid: 25 March 2013 House Deposit Paid: 19 April 2013 Re: Small Theatre Room Ideas?!!?! :? 10May 02, 2013 10:49 pm long cables are no issue. I think that any decent home theater store could advise on the installation requirements. there are a number of online supplies that can give you a ball park of costs for all in packages. Re: Small Theatre Room Ideas?!!?! :? 12May 04, 2013 5:16 pm i think in the right lit room the huge screen size and HD projectors are amazing. remember you are sitting back from the screen. Just immerses you more. Re: Small Theatre Room Ideas?!!?! :? 13May 04, 2013 5:46 pm I pretty much agree with what others have said regarding sound, 60” LED, sliding doors and soundproofing but I would not put the screen on the long wall as I think this will put you too close as the short wall is 3300. When it comes to power points I think you need to write a list of everything you will need one for and you may be surprised. I have 2 quads and a double and still needed a powerboard. Currently connected are TV, speakers, centre speaker, bass, DVD, amplifier, Foxtel, external drive, router, phone point, floor lamp, laptop, small fan-13 in total. Regards, Grumbles Re: Small Theatre Room Ideas?!!?! :? 14May 06, 2013 10:26 pm Tez-HG Isn't there a major gulf in picture quality between a good projector and a good LED TV. Doesn't the TV win this war? Not anymore! A sub $2000 projector will match and LED / Plasma in the right environment! A darker environment is definatelt required for a great image on a projector. Re: Small Theatre Room Ideas?!!?! :? 15Jun 16, 2013 3:39 pm You can have the one surge protected double powerpoint and then every normal double powerpoint down the line will be protected, so there's no need to have multiple surge protected powerpoints. You can also have a surge protector fitted to your switchboard to protect the whole house, not just the theatre room. Yes and no with the 7.1 vs 5.1, it depends how you sound proof the room, the quality of the system and whether or not you're an audiophile. If you have exposed plaster on the walls and roof the sound will bounce and you might as well have stereo with front and rear speakers. Place acoustic tiles on the roof and hang heavy curtains that cover walls, windows and doors and 7.1 will sound amazing. With the sliding doors, have them mounted inside the room rather than cavity sliders and this will allow you to hang the curtains on the doors for easier access. Re: Small Theatre Room Ideas?!!?! :? 16Jan 01, 2014 1:47 am We have a benq w1080st and its awesome. Best 3d outside a cinema ive seen and thats on a wall too with no screen. We have it mounted in the bedroom 5 feet from the wall and is producing a 100" image. Color, contrast and sharpness is incredable for a 1000 dollar pj. Buy from lmc and they will give you 2 pair of 3d glasses for free. Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4976 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12448 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6861 |
