Browse Forums Home Theatre & Automation Re: Speaker question 2Feb 14, 2013 8:11 am Yes, this will be fine. It is best to get the matching speakers across the front stage (Left, centre, right) for that tonal balance and seamless transition across the sound stage. The rears & sides you can get away with, with different speakers. The different subby will be fine also. Builder: Dennis Family Homes House: Hartley Facade: Provincial Suburb: Lyndhurst Moved in! http://cynash.blogspot.com You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9960 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6151 1 13125 |
