Browse Forums Home Theatre & Automation Re: Mounting a small LCD tv on wall with no stud 2Apr 10, 2008 4:08 pm In short if you like your tv then NO!!!
You need a stud and there are lots of different ways to acheive this but I would suggest this: The bracket mounts to the wall on the stud and the Tv remains in the alloted position using the offset of the bracket.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ or this depending on how far away from the stud you are... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Use no stud at your peril ![]() ![]() ![]() Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 3635 Hi I am new to this forum. Helping my son who has 2.5 acre property in south west. Just had a bore installed with total depth 30m and submersible pump supposed to be… 0 2315 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 1721 |
