Browse Forums Home Theatre & Automation 1 Apr 10, 2008 7:58 am Re: Not a bad set up 3Apr 10, 2008 12:57 pm Quite similar to Matto's old setup (and sort of my current one - go Vista Media Centre!).
I find it particularly interesting the way they've used the traditional cabinet versions of the Mordaunt-Short Avant 900i speakers (905i centre, 902i bookshelfs for left and right front) recessed into the front feature wall instead of the actual Avant Architect in-wall versions (AW 152 and AW 151 respectively) of the exact same speakers (which are pretty much the same price).... Beautiful sound either way. Good choice for what is sonically a nice quality, moderately sized setup. Re: Not a bad set up 4Apr 11, 2008 11:42 am Rod / Matt, how does this bit of the setup work?
http://www.flickr.com/photos/25496888@N04/2401218304/ Re: Not a bad set up 5Apr 11, 2008 12:10 pm kyton
would be a normal slot loading dvd player: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It would be mounted on the inside of the wall cavity and run back to the PC using a usb cable or similar. We have never used this method in the past and going forward probably wont either. Its a little OTT for my liking but the rest of the room holds some appeal. Thank you so much. This has been very helpful. We definitely wish to settle and get these people out of our life. They are trying to charge us interest on late… 7 14262 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16145 do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28277 |
