Browse Forums Home Theatre & Automation 1 Oct 25, 2012 7:26 pm Does the angle of the ceiling effect the speaker to ear response? In our new living area for the kids, I'd like to mount some speakers into the ceiling for a basic theatre set up but I'm not sure if it would work due to the angle of the ceiling.. So sitting in front of the TV the ceiling starts @ 2400mm on the right and rakes up to 3600mm on the left, which would mean the left speaker is roughly 1000mm higher than the right. Re: Ceiling mounted speakers in raked ceiling 2Oct 25, 2012 10:53 pm Hi Paul, We are having speakers in a raked ceiling, about 600mm difference in height. Our A/V installer said the speakers will be gimbal mounted and the height difference will not be a problem. Good luck! ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Ceiling mounted speakers in raked ceiling 3Oct 26, 2012 6:37 am PAB_34 Hi Paul, We are having speakers in a raked ceiling, about 600mm difference in height. Our A/V installer said the speakers will be gimbal mounted and the height difference will not be a problem. Good luck! Cheers, didn't know you could get gimble mounts for speakers... Re: Ceiling mounted speakers in raked ceiling 4Dec 11, 2012 9:10 pm The other way around this is to have an amp that compensates for distance - then it makes no difference at all. In basic terms you tell the amp the distance to the speaker and it calculates when to play the sound to each speaker to make it hit your ear at the same time. Most amps on the market >$500 have a feature such as this! Re: Ceiling mounted speakers in raked ceiling 5Dec 11, 2012 11:13 pm mattwalker The other way around this is to have an amp that compensates for distance - then it makes no difference at all. In basic terms you tell the amp the distance to the speaker and it calculates when to play the sound to each speaker to make it hit your ear at the same time. Most amps on the market >$500 have a feature such as this! Oh cool, thanks Matt I wasn't aware of this....... Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72483 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 6108 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2487 |
