Browse Forums Home Theatre & Automation If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8311 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7743 I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9565 |
