Browse Forums Home Theatre & Automation Re: Ceiling speaker installation 3Aug 06, 2012 8:50 pm It depends on the speaker you are looking at too. A lot of the higher end speakers are completely enclosed at the rear and makes no difference in regards to the insulation. If the insulation is in the way you could consider boxing the speaker and surrounding the box with insulation too. Most speakers are installed after the house is finished and therefore insulation is always almost moved in some way. Re: Ceiling speaker installation 4Aug 17, 2012 9:37 pm Hi matt, what type of speakers would you recommend? Had a look at your site, its great so ill definitally be getting the wall mounts from your site when my house is ready _________________ Building with EBH - Saville 30 @ The Ponds Building Blog - http://rabsndee.blogspot.com 22/08 - Slab Done 07/09 - Frames 16/09 - Roof 02/10 - Bricks 26/10 - Lockup 17/01 - Settlement Re: Ceiling speaker installation 5Aug 21, 2012 10:49 pm Depends on the sound you are looking for - in most a 6.5" in ceiling is fine but some area's an 8" is more suitable. Also depends on the type of sound you like - bigger is bassier!! Re: Ceiling speaker installation 8Aug 28, 2012 9:04 pm We have these on special if you are interested? http://www.thecableconnection.com.au/Opus-Slimiline-65-High-end-Indoor--Outdoor-In-Ceiling-speakers---Pair-.html Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thank you @ashington Homes for your reply! They just got back to me and offered credit for me to just take it as is. It was a less than quotes I got from ceiling… 6 1886 I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5382 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6388 |
