Browse Forums Home Theatre & Automation Re: Simple(ish) multi room audio 10Jul 30, 2012 10:00 pm Thanks for everyones input. After looking at Sonos and other amps, i think will go the Squezebox touch route (a big plus for misses, as it has a simple touch screen - which she likes) If i go down this route, can anyone recomend a stereo amp which could possible accept up to 4 sources input (possible future expansion) and has 4 sepearate zone outputs. ie. input 1 to zone 1, input 2 to zone 2 etc? Thanks for your help Re: Simple(ish) multi room audio 11Aug 01, 2012 8:09 pm bdydrp, I know I said it before but before you commit please do yourself a favour and checkout the sonos gear. It is the easiest, most expandable and easiest to use. The Squeezebox is cheaper but it is a different league and has its restrictions. I have used and owned both and the Sonos is far superior and much more wife friendly. Cheers, Matt Re: Simple(ish) multi room audio 12Aug 01, 2012 9:18 pm Matt, Thanks. So i can..i guess understand sonos more..could you explain how i would set up my needs then. I have a H/T which ill keep separate, then outdoor area (pre wired incase) and bathroom (also prewired incase). Do i need a sonos amp for each zone and that can be controlled with ipod/iphone? Does the amp have multiple outs? one for each zone? The standalone speakers, are they ok for use in Bathrooms? Sorry for the bombardment of questions, just trying to figure sonos out for my applications Thanks for your help Adam Re: Simple(ish) multi room audio 13Aug 01, 2012 10:50 pm Hi Adam, Ok first Sonos is controlled with your phone (iphone or android) and you can choose to do it cheap if you like. Using a Connect Amp you can run it in 1 zone or multiples if you use a couple of other devices. Each amp is good for 1 zone by itself but this is fixable if you know how. You can also use a connect to hookup to your home theatre amp and run it through other zones too. As for using a Play:3 in the bathroom there is nothing that says you cannot and reading other forums it seems pretty common. It is he kind of thing that playing with it shows you how easy it is - what state are you in? Re: Simple(ish) multi room audio 14Aug 05, 2012 5:06 pm Matt - Im in Sydney, NSW So basically, if i have a H/T amp with a 3rd zone, i could use a connect to power zone 3 to speakers, then another connect amp to power another zone? when you say "Each amp is good for 1 zone by itself but this is fixable if you know how" do you mean using an A&B Switch for more zones. Really sounds like i need to get to a distrubutor to check it out properly Re: Simple(ish) multi room audio 15Aug 05, 2012 7:16 pm bdydrp Matt - Im in Sydney, NSW So basically, if i have a H/T amp with a 3rd zone, i could use a connect to power zone 3 to speakers, then another connect amp to power another zone? when you say "Each amp is good for 1 zone by itself but this is fixable if you know how" do you mean using an A&B Switch for more zones. Really sounds like i need to get to a distrubutor to check it out properly Unfortunately Eastwood Hifi is dropping Sonos, but they may still have something there to check out, and may have runout sale. Otherwise from memory Len Wallis in Lane Cove has them. Check the Sonos site for resellers. What you said is basically correct; have a Connect into my Yamaha A2000, whereas have another 4 Connect:AMP into bedroom, bathroom, library and soon ourdoors speakers. Due to wife factor, also have a Play:5 with is synced with the Connect, so the living area gets filled with sound from both the Play:5 and the Paradigm connected to the A2000. Currently controlling it with my iPhone, iPad and a dedicated Nexus 7. Re: Simple(ish) multi room audio 16Aug 06, 2012 8:47 pm PHL has summed it up well - let me know if you need pricing etc! Hey, I am wanting to add a second toilet to my house, bit we have limited room. There is a hallway/entry that is never used, so was thinking this could be an option. Only… 0 4716 Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13732 sorry mate, not wasting more time on this. Youve completely missed the mark on some fundamentals and regardless of how many times i try and put it to you differently, you… 11 9192 |
