Browse Forums Home Theatre & Automation 1 Jun 19, 2012 12:47 pm Hoping some advice. Build has just started and I am in the process of getting all the gear together for my Media room. Once the frame goes up I have the opportunity to do the pre-wire for my speakers. My receiver is a Yamaha rx-v2071 and will be utilising the 9.2 channels. 7.2 in the Media room and 2.0 as a seperate zone in the outdoor alfresco area. My question is that I have bought a 7.2 double gang wallplate from http://www.selby.com.au/7-2-home-theatr ... 1144b.html and am interested in how I am supposed to mount it pre-plaster.. Is it just a matter of placing two stud bracket mounts? Or is there a different solution? Re: Mounting a double gang wallplate 2Jun 19, 2012 1:00 pm either a dual wall plate bracket and or ask selby... looks lieka yank styple wall plate instead of nice looking clipsal/ hpm wall plate Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Mounting a double gang wallplate 3Jun 19, 2012 4:07 pm Might have been easier to get two single speaker wall plates and mount them one on top of the other with a little separation, that way you could just hammer in two stud brackets ready to go (after cable run). Builder: Dennis Family Homes House: Hartley Facade: Provincial Suburb: Lyndhurst Moved in! http://cynash.blogspot.com Mounting a double gang wallplate 4Jun 19, 2012 4:16 pm I'm not aware of any fixed brackets commonly available in Australia to install 2 gang plates like these. You can install after the plaster is up using two C clips or a Clipsal 154/2 bracket - you should be able to order one of these at any electrical wholesaler. Paul Re: Mounting a double gang wallplate 5Jun 19, 2012 4:18 pm I think clipsal make a double bracket, ask at your local electrical wholesaler, if they have one they should have no problems letting you try it on for size in the shop so take the plate with you! Or you could nail a standard plate in and then use a plaster bracket for the other side, the ones that look like a C! 2 Mounting a double gang wallplate 6Jun 19, 2012 4:42 pm I wouldn't recommend installing a standard bracket because it isn't open at the top like a C clip, so it will foul the connectors on the back of the plate. Installing a bracket after plaster isn't a big deal - just mark the location and height of the cable on your slab with crayon. Paul Re: Mounting a double gang wallplate 7Jun 20, 2012 11:45 am paulw11 I wouldn't recommend installing a standard bracket because it isn't open at the top like a C clip, so it will foul the connectors on the back of the plate. Installing a bracket after plaster isn't a big deal - just mark the location and height of the cable on your slab with crayon. Paul Thanks for the advice Paul - I think I will go with the dual C clips. Now to hope that the plasterer doesnt stuff things up. Re: Mounting a double gang wallplate 8Jun 20, 2012 9:15 pm Take note of all your measurements, and take a photo when your done, 9 times out of 10 you will return to a wall of plaster! Although sometimes the plaster does pull the cables through! It might help to tape them together, all though with a double hole like that it should be easy to fish the cables out!! Re: Mounting a double gang wallplate 9Jul 13, 2012 11:19 pm The double c clips will work but it is hard to install. There is no great way of doing it but with a wallplate like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There is no real need to fix it with anything other than a few plaster screws. Its not like you are pulling on the plate regularly and therefore 4 well placed screws will do the job just fine! Cheers, Matt Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5867 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16150 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3548 |
