Browse Forums Home Theatre & Automation 1 Mar 09, 2012 3:36 pm hi, just wondering if anyone out there can help me as im definitely no handyman/electrician etc. i will try and give as much info as i can and hopefully anyone with knowledge in the area or has been through the process recently can help me out. we want to mount a 60 inch plasma tv to the wall in our living room. on our electrical plans we have noted for the tv point and power point to be 1600mm up the wall. we will be having a lowline entertainment unit under it for the dvd player...foxtel...playstation 3 etc....and also want the cables to be hidden behind the wall. so the main questions i guess are, do we need to ask our builder to put in extra support/noggins etc to hold a 60 inch plasma? is this costly etc... also how do we go about hiding the cables, is this easy? we have an electrician mate so is that who does it etc? and is bracket type a big issue..lots of varietys etc? we want the tv as close to the wall as possible? what cost are we looking at all up? any help would be great thanks. Re: wall mounted plasma/hidden cables 2Mar 09, 2012 3:53 pm More noggins wouldn't hurt but most brackets have adjustable widths so they can go directly into the studs. Hiding the cables needs a bit more thought. But to finish you need a few of these around - http://www.4cabling.com.au/products/Bul ... White.html Building with Jandson Homes - Eclipse 18. http://adgnetworks.blogspot.com/ Re: wall mounted plasma/hidden cables 3Mar 09, 2012 4:30 pm If you are at or pre framing stage i would definately run any cableing you need, at least up into the roof space as well as down to the floor. The reason for running up is that later you may decide to run a media centre and you can bring your data or hdmi down a wall cavity. Also in the not too distant future all of our content will be coming in via data. I rarely use rf anymore and when I do its recorded on the pc for viewing when I'm ready. Re: wall mounted plasma/hidden cables 4Apr 08, 2012 10:38 pm I've asked our electrician to look into: arlington recessed tv boxes http://www.youtube.com/watch?v=uq5qDS2mTDE Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Not sure they're available in Australia, but I can order them in through amazon if need be Re: wall mounted plasma/hidden cables 5Apr 09, 2012 1:39 pm Am doing a similar thing. Any suggestions for the power plug ?? Re: wall mounted plasma/hidden cables 6Apr 10, 2012 3:39 pm I found this via pinterest a while ago http://www.houseofhepworths.com/2012/01 ... the-cords/ Hope it helps A blog about our renovation http://notmynightmare.blogspot.com.au/ Re: wall mounted plasma/hidden cables 7May 10, 2012 3:44 pm In our HT we got our Data Cabler to put a provision for wall mounted TV in. It basically consisted of two wall plate brackets (tv height and normal lowline unit height) which were then plastered over...we have the heights though so we can just knock holes through once we get the big tv. He also put a nice fat piece of conduit through the noggin so we could easily drop the cables down from the top to the bottom when we install it. Brilliantly easy to do at frame stage and will save us alot of headaches when we've won the lottery and bought a new TV! Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: wall mounted plasma/hidden cables 8Jul 13, 2012 11:42 pm If you get stuck we have these to recess power points (and any other wallplate) here: http://www.thecableconnection.com.au/Wa ... walls.html Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: wall mounted plasma/hidden cables 9Jul 15, 2012 9:15 pm mattwalker If you get stuck we have these to recess power points (and any other wallplate) here: http://www.thecableconnection.com.au/Wa ... walls.html Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Have used these plenty of times, heaps of room for power lead plus ya drill a hole out in the bottom for hdmi, coax etc cables to come through.. Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72340 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5195 Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16153 |
