Browse Forums Home Theatre & Automation 1 Feb 11, 2012 6:33 am What are my options like to get more cabling done after moving in? When we did up the plans for our house my wife had just been diagnosed, so to be honest I didn't have my head in the right spot and I've missed a few things. Nothing I want done is extravagant, mainly things like not having anywhere near enough data points. But yeah, just got that whole double story issue. Thanks for any advice given Land Deposit - 18/12/2009 Became a land Baron - 21/12/2010 Site Start - 27/1/2011 All moved in!! Re: Solutions for extra cabling in double story post handove 2Feb 11, 2012 7:39 am If you are prepared to have access holes cut then repaired sure but it will be very expensive labour wise. Holes would be on the walls too. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Solutions for extra cabling in double story post handover 3Feb 11, 2012 10:16 am It depends on the type of construction and where you want the points. Brick veneer with a tile roof and points on external walls isn't too hard. Double brick, interior walls or Colorbond roof increase the difficulty and therefore the cost. As Pugs says in some cases the easiest way is to make holes and then patch and paint. Paul We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4086 In the end, two pieces of treated timber (20mm thick) were bolted onto the joists and planed when there was too much sticking out. Passed inspection. 13 7800 I would find out how deep your clay base is and depending on the depth install a cut off drain which is more than a normal agi drain. Where the neighbouring walls is… 2 3147 |
