Browse Forums Home Theatre & Automation 1 Sep 29, 2011 11:19 pm The room off our kitchen is going to have a wall mounted TV. We have no idea where to put the foxtel box. We are thinking that our only option is in one of the cupboards in the kitchen, and you have to reach around to switch the channel over. Some more suggestions would be great Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: Help with wall mounted TV's 4Sep 30, 2011 10:01 am Lowline cabinet with in wall cabling... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Help with wall mounted TV's 5Sep 30, 2011 2:48 pm We didnt want a lowline or any shelves on that wall, We will have the cabinet set up in the media room, but didnt want any shelves etc on that wall, we are also having all the cables hidden in the wall, so they dont hang down. Thats ok, we might just have to hide the foxtel box in the kitchen. Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Re: Help with wall mounted TV's 6Sep 30, 2011 6:45 pm acrebuild1 The room off our kitchen is going to have a wall mounted TV. We have no idea where to put the foxtel box. We are thinking that our only option is in one of the cupboards in the kitchen, and you have to reach around to switch the channel over. Some more suggestions would be great if it is just standard Foxtel box you can put it just behind the TV, between TV and the wall, just need to make sure you have got enough space there. [url]ACMA registered cable, Government endorsed Antenna Installer[/url] Re: Help with wall mounted TV's 7Sep 30, 2011 7:31 pm Get a remote extender and it can do anywhere (within audio/video cable reach). We had ours in a the media room and used a "multi-room adapter" for the remote. Connected via a 10m RCA cable from selby's accoustics. Worked great. I didn't want a low line unit under Wall mount TV either. Re: Help with wall mounted TV's 8Oct 04, 2011 3:28 pm I agree with fitting it behind the TV if there's enough room and it doesn't cause airflow issues. Or make up a shelf the exact same footprint as the foxtel box that hangs off the wall mount and you can sit the box on it either above or below the tv. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Help with wall mounted TV's 9Oct 07, 2011 9:30 am Sierra is right. You can put the Foxtel box anywhere and run cables from it to the TV. For controlling it you (should - wireless IR systems are nowhere near as stable/reliable as wired ones) run some Cat5E cable (standard old-school phone wire will also work - it only needs 3 cores/conductors, just Cat5E is more commonly readily available these days...) from the Foxtel box to the TV for an IR repeater, then all you need is a small IR receiver/target stuck on the front of the TV and nothing else needs to be in the room. Just make sure the IR system is GUARANTEED to work with the Foxtel box (version) you get! Re: Help with wall mounted TV's 10Oct 07, 2011 3:29 pm Thanks Rod. i have the foxtel guy coming next week, so he should know what to do. (you would think) My electrician is on site until tomorrow arvo so i will ask him tomorrow also Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Help with wall mounted TV's 11Oct 07, 2011 4:41 pm acrebuild1 Thanks Rod. i have the foxtel guy coming next week, so he should know what to do. (you would think) My electrician is on site until tomorrow arvo so i will ask him tomorrow also based on my experience I think you might be expecting a bit much of your Foxtel installer Re: Help with wall mounted TV's 12Oct 07, 2011 4:51 pm paulw11 acrebuild1 Thanks Rod. i have the foxtel guy coming next week, so he should know what to do. (you would think) My electrician is on site until tomorrow arvo so i will ask him tomorrow also based on my experience I think you might be expecting a bit much of your Foxtel installer Agreed. Re: Help with wall mounted TV's 13Oct 07, 2011 5:14 pm acrebuild1 Thanks Rod. i have the foxtel guy coming next week, so he should know what to do. (you would think) Foxtel installer will do only what he is get paid for : 1. Run Foxtel cable 2. Install skirting plate or wall plate, and 3. connect Foxtel box to this wall plate. You should not expect from Foxtel installer to run cables inside the wall, Foxtel installer is not getting paid for this. [url]ACMA registered cable, Government endorsed Antenna Installer[/url] Re: Help with wall mounted TV's 14Oct 07, 2011 5:47 pm Damm straight... Be why i offer clients to run a conduit for the foxtel guy especially for internal walls Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Help with wall mounted TV's 15Oct 07, 2011 6:17 pm I shouldn't be too hard on the installers. They do what they are paid to do - and they aren't paid to help with whole house AV integration Re: Help with wall mounted TV's 16Oct 07, 2011 7:12 pm ok, thanks for the thumbs up guys. Our Acreage Build The Lakeview Lodge - Beechwood Homes 01/04/10 YES 2010 - Deposit paid 23/09 - PCI CANCELLED 28/09 - PCI - will it happen.-18 months later 07/10/11 - ITS OURS..WOOHOO Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 68161 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 1329 Thanks for your reply! All valid points and I agree with you on many of them. I am in QLD, any recommendations on a construction lawyer would be helpful 3 2052 |
