Browse Forums Home Theatre & Automation 1 Aug 23, 2011 10:01 pm Hi, I have a quote for data cabling that I'm hoping to get revised tomorrow. Currently its >5K for 16 network points (CAT5E 2*8) plus RG6 points * 4, and some speaker cabling, digital antenna, AV cabinet and wall plates. Currently it might be including wiring for the alarm but it seems expensive. Can someone recommend me someone in Victoria to get a quote from ? I'm building in the South Eastern suburbs. I'm planning on data cabling, 1 double point per room * 3 bedrooms and 3 (or 4) double points in the study, and a couple for the lounge / family room. I did have in-wall speakers in my last quote but I don't strictly need them. RG6 / TV points are a nice to have as well. Thanks Re: Data cabling recommendation Victoria 2Aug 24, 2011 8:55 am I think I might be going with connectedliving. I haven't contacted them, but their website is slick. I emailed argustechnologies for an appointment twice without a response. I contacted techlife, but they turned me down, because my mid suburban build isn't part of a fiber/nbn community yet. 13-08 Moved in 13-05 Build restart 13-04 VMIA compensation 12-08 Builder liquidation 12-03 Fixing 11-12 Lockup 11-11 Frame 11-09 Slab 11-09 Start 11-07 Contract 10-11 2K deposit 10-06 Titled land Re: Data cabling recommendation Victoria 3Aug 24, 2011 8:57 am I could do all of that cabling/Antenna/wallplates for probably about half that amount... - PM sent... Re: Data cabling recommendation Victoria 4Oct 05, 2011 8:22 pm My builder charge $75 per data point, $55 for double power point, $90 for tv points, $350 for home theater wiring(5.1 without plates, $550 with plates), $50 for extra light points, $115 for down lights, Converting standard light point to down light is $65, $60 for dimmer, $45 for extra switches, $100 for weather proof double power point, $600 for intercom system, $1100 for a security system with 3 sensors, $285 for telephone run to home etc Does these prices are reasonable or is there anything in the list if I do after handover. Re: Data cabling recommendation Victoria 5Jan 19, 2012 3:24 pm Agreed with almost half that... should be around 3K depending on cabnet installed.. Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Re: Data cabling recommendation Victoria 6Feb 07, 2012 10:33 pm There is plenty of guys out there who can do this work other than the big guys.... give the smaller guy a go and you may be pleasantly suprised! Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20651 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13846 For reference, this is the Austlii reference. My take on this is, that they would be breaking the law denying access to a homeowner in Victoria, or their agent from having… 1 9094 |
