Browse Forums Home Theatre & Automation Re: Wall mounted TV height 2Aug 15, 2011 9:35 pm Depends. In the bedroom or in the lounge ? In the lounge, sit in your lounge chair and you need to be looking straight ahead at eye level, thats where it should go. In the bedroom whatever prone position you are most comfortable with is where it should be. On the ceiling above your head even works. Re: Wall mounted TV height 4Aug 16, 2011 4:44 pm The ideal height is to have the TV mounted so that the bottom third is approximately 1100mm from the ground (ie about the same height as your light switches.) This changes though if you are using a tilting bracket. You can put the TV much higher and still achieve the correct viewing angle by simply tilting the TV down a little. The best place to put your TV however is in the most aesthetically pleasing position on the wall and purchase bracket to suit that spot! Re: Wall mounted TV height 6Aug 17, 2011 10:32 am If i was to recess the TV like the attached picture, how much space should i leave around the TV? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Uploaded with ImageShack.us Re: Wall mounted TV height 7Aug 17, 2011 8:09 pm Hi motef, This one is designated by the manufacturer. Most will recommend a minimum distance of 100mm around all edges but there are ways around this! Cheers, Matt Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72334 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7741 Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10682 |
