Browse Forums Home Theatre & Automation 1 Jul 12, 2011 3:54 pm Hi everyone ,I don't know this is wright place for you ,Do you need to extend the distance from your computer to a USB device such as a printer or scanner? According to the USB specification, you can use passive extension cables (i.e., cables without an active repeater chip in them) for distances up to 16 feet. Beyond sixteen feet, you need a cable that will boost the signal in order to avoid losing data or, worse yet, damaging USB equipment.. THANKS IN ADVANCE.. Re: USB Extension Cables 2Jul 15, 2011 5:59 pm Plenty options here up to 5m, mostly passive: http://www.auspcmarket.com.au/products/383/ A safer option over longer distances might be something like this: http://www.auspcmarket.com.au/info/CB-USBEX/383/ It carries USB over Ethernet up to 150feet. Re: USB Extension Cables 3Jul 16, 2011 7:12 pm With experience trying to use 3 extensions together, it doesn't work. Will never break any of your goods, although trying to get the adapters to work does not provide any help. Would definitely go with cray-'s suggestion about buying a longer one and I didn't even know about the Ethernet one either. Re: USB Extension Cables 4Jul 23, 2011 4:43 pm I have just got a few of these in last week...have a look here: http://thecableconnection.com.au/defaul ... searchview These seem to be fairly popular: http://thecableconnection.com.au/5M-USB ... F6E38.html Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8582 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5566 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6222 |
