Browse Forums Home Theatre & Automation 1 Jul 11, 2011 10:40 pm Re: Need a HDMI Cable? ... read this first! 3Jul 15, 2011 9:46 am Good to see someone writing something useful! just cler this up for me...what is HDMI with Ethernet? (I understand the HDMI part, but are they dual purpose or something?) Re: Need a HDMI Cable? ... read this first! 6Jul 15, 2011 11:22 am also check out the computer stores such as M S Y their most expensive is 30 bucks.
Consumer affairs should get onto this because these cables are such a rip off Re: Need a HDMI Cable? ... read this first! 7Jul 15, 2011 5:18 pm Nice one Matty! Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Need a HDMI Cable? ... read this first! 8Jul 15, 2011 9:54 pm Good to know because some cables are ridiculously overpriced. I had to buy a new foxtel cable and they wanted almost $200 to post one to me. I was sure I'd be able to get it cheaper elsewhere. Stopped in at D!ck Smith and sure enough they were much cheaper at $60. I didn't bother looking anywhere else, I figured I already saved myself $140 so I was happy Success is the result of good judgment, good judgment is the result of experience, and experience is often the result of bad judgment! Re: Need a HDMI Cable? ... read this first! 9Jul 16, 2011 10:26 am Thanks guys!! I am really happy with this write up Sir Snagger Good to see someone writing something useful! just cler this up for me...what is HDMI with Ethernet? (I understand the HDMI part, but are they dual purpose or something?) This means that the cable is also capable of transferring the internet through it. A HDMI cable is many things now: - Transfers high quality uncompressed digital audio and video signals - Sends the sound back from your TV to your amp (used to need a seperate cable) - Transfers ethernet (intenet) between devices - Sends electronics pulses for communication between devices (CEC) Amongst other things! Re: Need a HDMI Cable? ... read this first! 10Jul 16, 2011 10:49 am mattwalker It is reinforcing everything I have said for the last 6 years - just because it costs more doesn't mean it is necessarily better. Same goes for windows, and adding it may even cost less and be better... Well done Matt... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Need a HDMI Cable? ... read this first! 11Jul 23, 2011 5:44 pm It would seem that there are no cheap HDMI cables available in Canberra... What a week for cables going to our capital! Re: Need a HDMI Cable? ... read this first! 12Aug 15, 2011 12:16 am Aldi in Melbourne will have 2 meter HDMI cables for under $10 later this week. Success is the result of good judgment, good judgment is the result of experience, and experience is often the result of bad judgment! Re: Need a HDMI Cable? ... read this first! 14Sep 20, 2011 3:24 pm The HDMI cables at The Cable Connection are cheaper and every bit as good if not better than what I saw on the EzyHD site... Re: Need a HDMI Cable? ... read this first! 15Apr 19, 2012 11:35 am A further HDMI issue... There have been reports on some electronics service sites of EXPENSIVE HDMI cables actually causing problems & reducing the quality of video. The problem was with extra thick "monster" style cables which it is thought may have too much capacitance. In the cases given, fitting a cheaper cable solved the problem. Apparently it is a hit & miss situation whether such a cable will cause a problem even with two supposedly identical signal sources & TVs. One may work fine & the other won't. Regards, Brian. Re: Need a HDMI Cable? ... read this first! 16Jul 14, 2012 12:43 am Hi Brian, It is a balance getting it all right. Lucky for me I don't have this "Monster" of an issue! Re: Need a HDMI Cable? ... read this first! 17Jul 30, 2012 11:55 pm Remarkable..............Thanks for the info Matt Building in Blackwood Park 2012/13 Land settled 8/8/12 Contract signed 6/11/12 Encumbrance approval 24/12/12 Development Approval 24/4/13 Slab Poured 8/7/13 Re: Need a HDMI Cable? ... read this first! 19Aug 13, 2013 11:29 am Not quite as old, but still an old post. Again why bother??? Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ nothing to do with salespeole. you'd do well to read and ccomprehend the post before bashing away at the keys with some negative comment again. 4 5044 Last year, 50% of their staffs left. Is it going be bankruptcy this year? 10 30970 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 3808 |
