We upgraded our cables to cat 6 but these says 5e, the brand is Digitek, can anyone tell me more about them?
Browse Forums Home Theatre & Automation Re: What types of cables are these? 2Jul 10, 2011 6:57 pm Looks like you didn't get your cat6 cable Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: What types of cables are these? 3Jul 10, 2011 6:59 pm 5e and 6 both support 1Gbps data transfer. That's a really important factor to remember.
The differences between the 2 are minor and relate to transmission characteristics that make no real difference in residential applications. http://www.cat-5-cable-company.com/faq- ... cat5e.html The second image you have posted seems to just be electrical cable, not data cable. Re: What types of cables are these? 4Jul 10, 2011 7:03 pm Cat 5e stands for 'cat 5 enhanced', which is not capable of the same speeds as cat6. If you have paid for cat6 cables, get onto your builder and advise them that they have installed cat5e instead of cat6. Info is from my hubby who is a licensed data cabler. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: What types of cables are these? 5Jul 10, 2011 7:06 pm ...however, data cable speeds are also determined by the devices you're running on them. So depending on the speed of the equipment your running, you may not notice any difference between cat5e and cat6. However, if you paid for cat6 as an upgrade I'd advise your builder. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au What types of cables are these? 6Jul 10, 2011 7:14 pm Agree with HomeAngels. If you have paid for Cat6, get them to run it. Re: What types of cables are these? 7Jul 11, 2011 2:08 pm The bottom line is that you just didn't get cat6 as asked for. There is a difference in price, so get on to them about it! Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: What types of cables are these? 9Jul 23, 2011 4:50 pm Both are capable of 1 Gbps transfer 1 way - but I believe that Cat6 can do it in both directions at the same time. That said - if you paid for Cat6 you should definately have it. Re: What types of cables are these? 10Jul 23, 2011 5:25 pm The differences are mainly to do with transmission quality. CAT5e will have no probems running 1000BASE-T in a residential application (bothways, as there are seperate send a receive pairs, and it's a full-duplex connection) Re: What types of cables are these? 11Jul 23, 2011 7:25 pm Who cares if Cat5e is good enough!!! You paid for Cat6 and that is what must be used! I bet the builder charged more to upgrade to Cat6!!!!! Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: What types of cables are these? 13Jul 24, 2011 2:35 am mattwalker Both are capable of 1 Gbps transfer 1 way - but I believe that Cat6 can do it in both directions at the same time. That said - if you paid for Cat6 you should definately have it. try both ways... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: What types of cables are these? 15Jul 24, 2011 1:00 pm Casa2 A bit cryptic. how so?? just the fact that 1GB is a duplex speed ie both directions... sure if you are streaming you hardly get 1GB speeds from either Cat5e/6 due to hardware like hard drives and other on board related through puts.. the whole 1GB sized tube is there as opposed to the 100MB tube. which at the end of the day is relaly determid by the network hardware as stated above. the whole point of cabling is so you have a strong back bone of your network. if you have a weak/ underpreforming backbone it won't matter is you have 20 600GB 10K RPM hard drives as your storage medimum as the backbone is the weakest link and when it really comes down to it the way the cable is constructed is the whole reason Cat6 is better is because of tighter twists on the pairs and the internal cable divider which remove cross talk and improve frequency handling hence why Cat6 is capable of doing 10GBE if terminated/ run propperly. now back to the subject as ofr the OP's issues if you paid for Cat6 demand Cat6. the other cable is power cable Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Building Standards; Getting It Right! Hi, sorry if this is the wrong place - I’m new to the property/building journey (trying to buy my first home) so not sure where/who to go with these sorts of… 0 19158 |
