Browse Forums Home Theatre & Automation Re: How to install bookshelf speakers on a brick wall??? 2Jul 07, 2011 3:34 pm Angelblue Hi there, Just wondering if anyone can tell me what is the best way of installing bookshelf speakers on an internal brick wall? Any ideas??? depends on the speakers. ie how much they weight.. and or if they have any mounting options.. Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: How to install bookshelf speakers on a brick wall??? 3Jul 07, 2011 4:14 pm my husband has purchased some brackets for them to sit on. However, my main concern is - as these speakers will sit on the wall behind us. What is the best way to run the cord/cable from the amp to the speakers. My husband said that he would need to cut into the wall to run the cables up into the ceiling, then run the cable in the roof cavity to the other wall. Then cut down this wall to the desired height. This sounds incredibly involved and messy. But, I would like the more visually appealling option. Is'nt there an easier way? Re: How to install bookshelf speakers on a brick wall??? 4Jul 07, 2011 4:35 pm Our speaker cables run through the wall behind the speaker, along inside the roof and back down the wall to the amp. You can't see the cables as they are covered by the mounting bracket for the speakers. Our speakers were designed to be wall mounted so the mounting plate hides things nicely. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: How to install bookshelf speakers on a brick wall??? 6Jul 07, 2011 7:38 pm We didn't have to cut into the wall at all, except of course just a tiny hole to poke the wires through. The wires fit easily down the wall cavity. Also, because they're mounted up high the wires didn't have to go down far, which makes it a lot easier. I have attached a pic I just took. Excuse the bad quality of it, I took it on my phone. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: How to install bookshelf speakers on a brick wall??? 7Jul 08, 2011 8:36 am Angelblue Is'nt there an easier way? In short, no. Not if you want the wires hidden inside the wall(s). And doing it inside a brick wall is mildly challenging at best... Re: How to install bookshelf speakers on a brick wall??? 8Jul 23, 2011 4:52 pm Have a look here for a few ideas: http://thecableconnectionco.blogspot.co ... ll-or.html I have done this many times ... inside the brick whilst not impossible is extremely hard. It may be easier to use a clear cote cable and wind it down the brickwork hiding it in the mortar... can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4444 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 7898 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10892 |
