Browse Forums Home Theatre & Automation 1 Jun 22, 2011 5:27 pm i want to purchase these speaker for my home cinema room what dou you think The MGR750 4 WAY reproduces soaring vocals and stirring bass in music to the next level ! 3 Tweeters will give you crystal clear sound, these are excellent for both music and theater applications properties. The cones can move fast with minimal flexing, making for a superior stable bass response. The MGR750 four-way speaker is simply designed for the true audio enthusiast. This pair produces strong, sophisticated sound - perfect for most rooms. Design & Manufacturing by our South German partners Power Handling 750 WATT POWER HANDLING 310 RMS WATT Sensitivity 89 db Weight: 2.6 kg per speaker Frequency response 35 Hz- 20 KHz 8 Ohm Features 3 Tweeters Dimensions 8 inch Length 270mm, Cut out 230mm, Depth 122mm Re: in ceiling speaker what do you think 3Jun 22, 2011 5:58 pm $200 a pair im going to install 5 2 front 1 centre 2 rear onkyo tx-sr608 receiver sharp 3d projector Re: in ceiling speaker what do you think 4Jun 22, 2011 9:28 pm 'The Sound Monster Listen to this fantastic richness of pure sound. The acoustic intensification of sound, musical properties and vocal tones of this speaker are exceptional' With aa advertising line like that I would run a mile. Slab poured 21/04/2011 Frame finished 27/05/2011 Moved in 07/11/2011 Re: in ceiling speaker what do you think 5Jun 23, 2011 8:02 am I gotta say, when compared to all of the known brand speakers I'm aware of $200 for speakers that claim the specs these things do (310WRMS power handling!!!!, down to 35Hz!) is miraculous! Normally speakers that actually can perform at those levels (and many of even the most expensive don't) cost 10+ times that much... Re: in ceiling speaker what do you think 6Jul 23, 2011 5:26 pm Sounds like a case of the "white van man" to me ... Be a little wary. No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 6636 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2456 |
