Browse Forums Home Theatre & Automation Re: Advice for 3D TV 2Jun 04, 2011 11:46 pm Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: Advice for 3D TV 7Jul 28, 2011 4:43 pm Sierra I dont believe you need to upgrade your amp either, but AFAIK a single optical out cannot carry a HD audio signal (5.1 / 7.1 etc). You will need HDMI. S/PDIF (the spec for digital coaxial and optical audio transmission cables) can do: Dolby Digital 5.1 DTS 5.1 Dolby Digital EX 6.1 DTS-ES 6.1 However if you want to do HD Audio or 7.1 then you need HDMI: Any 7.1 channel Dolby Digital Plus / TrueHD DTS HD / HD MA The limitation isn't the cables though (like the whole optical speed-of-light thing), it's actually a limitation of the S/PDIF spec. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17759 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13842 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6903 |
