Browse Forums Home Theatre & Automation 1 Jun 04, 2011 8:27 pm Hi All, I am currently looking at purchasing a 3D TV, however I have just been informed that I need to upgrade my DVD player to a Blue Ray 3D player and also upgrade my amp to one with a HDMI input, I understand that my DVD player will require upgraqding but can't see why my amp would require upgrading, Now my amp does not have HDMI input but does have the optical input, will this be sufficient or is the upgrade of the amp a must aswell Cheers Darren Re: Advice for 3D TV 2Jun 04, 2011 11:46 pm Hi Darren, To play 3D movies, you'll definitely have to go to a 3D Bluray player. The amp would make life easy but it's not absolutely essential if you want to get started. You would connect the 3D Bluray to your 3D TV directly using the HDMI connection. Make sure you get a HDMI 1.4 cable, that's the version of HDMI that can carry the 3D stuff and that's also why that cable may be more expensive than some of the standard HDMI cables. Then you would use the Audio out connection of the TV into one of the inputs of your standard Amp. If your TV has the optical Audio output then connect that to one of the optical inputs on the amp and use that for sound only. Later on, if you want to get a new AV receiver, again make sure it accepts HDMI 1.4 to pass 3D through it. SK Build thread: viewtopic.php?f=31&t=34120 Handover 23 Dec 11 Squatting 21 Dec 11 Fixed 12 Oct 11 Plastered 31 Aug 2011 Framed 7 June 2011 Site Start 7 Feb 2011 Land Titled 18 Jan 2010 Land Deposit 25 Jun 2009 Re: Advice for 3D TV 3Jun 05, 2011 4:11 pm Thanks for the reply Eskay, I have decided to put the TV off a few months, in that few month wait i will pick up a the Blue ray 3d player and a new amp however it seems a shame to just discard the current amp,it has such a great sound, anywho i guess it's time for me to move with the technology Cheers Darren Re: Advice for 3D TV 7Jul 28, 2011 4:43 pm Sierra I dont believe you need to upgrade your amp either, but AFAIK a single optical out cannot carry a HD audio signal (5.1 / 7.1 etc). You will need HDMI. S/PDIF (the spec for digital coaxial and optical audio transmission cables) can do: Dolby Digital 5.1 DTS 5.1 Dolby Digital EX 6.1 DTS-ES 6.1 However if you want to do HD Audio or 7.1 then you need HDMI: Any 7.1 channel Dolby Digital Plus / TrueHD DTS HD / HD MA The limitation isn't the cables though (like the whole optical speed-of-light thing), it's actually a limitation of the S/PDIF spec. Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15079 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13761 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6830 |
