Browse Forums Home Theatre & Automation 1 May 29, 2011 8:18 pm Hi All I've got a new house which we are just about to start building. I'm taking the opportunity to put in a media room in the basement level (we are building on a hill side). Size 5.3x 4.3m The basement floor plan: To enable us to call it a room I've had to place a window at the back of the room; else I'm told it can only officially be called storage. My thoughts are - and I welcome much criticism here * Place a screen at the end of the room (joining the storage room) I am thinking either 92 or 100 inch fixed. * Ceiling mounted projector; I'm thinking on using a Benq W1000+ - it seems quite cost effective and later when 3D Becomes more cost effective I won't kick myself when I upgrade it. * Run 2 x HDMI and a Recessed power point in the ceiling where the projector will be located HDMI's to run back to where I'll have amp. * Install cabling in-wall to outputs for center, both fronts, sides and rear (7.1). * I've already got some decent (I think) floor standing magnat fronts, center and powered amp - the gear is getting a touch older but it still seems really good; my current amp is a denon but I'm going I think to buy a Yamaha 7.1 with all the HDMI stuff to replace it. * My builder is contracted to use sound insulation in the walls and ceiling as well as sound gyprock (soundcheck?) on the walls and ceiling. * Carpet on the floors - This is where I am up to; my questions so far (beyond no doubt errors in my current plan listed above) * what should I put on the walls - I note some people hang full length curtains across some or all walls - I assume this is for sound deadening. * ceiling and lighting? * Suggested colours for walls (optional curtains?) floor colours and ceiling? (I know this is personal taste probably but I'm keen for input). * I'd like to step the room but I'm not sure this can be done (may not be possible). * is there value in what kind of doors I have on the room; also even though there is a window there should I consider have it gyprocked over (and just having the window cavity there in the event we decide to sell one day and then open the wall back up to expose it?) I'm really keen for peoples input on these and any ideas you may all have! Fire away. Cheers Mark Re: Suggestions for Media Room Setup 2May 29, 2011 8:41 pm Hi, What sort of speaker wires wud u be runing thru the wall?, wud u be installing speaker wall plates? I am thinking of getting my sparky to put some conduits thru the wall at places speakers will be placed and then to pull the wire later. I will be having a 100inch fixed screen, JVCX3 projector, Denon 4810amp, Paradigm front,center, sub and klipsch surr speakers Re: Suggestions for Media Room Setup 3May 29, 2011 9:21 pm I was going to use 12 AWG speaker cable and terminate them on wall plates. I've purchased in the past plates from cablechick.com.au and had a pretty good result; I got my sparky to do it in our previous place; we didn't have a dedicated room so I used in-ceiling speakers at the rear and plates for the fronts and center. Worked well. I'm sure there are cheaper and more expensive options there but that seemed good. This though will be my first dedicated HT room and I'm hoping to only need to do it once (for a while atleast) - so I'm trying to guess the pit falls before I start. It sounds like your setup will be very nice! I haven't worked out what surround speakers to use in the room; I'm not going (I don't think) to do in-wall or in-ceiling in my room; rather have speaker plates for every speaker point and wire it back to 1 or 2 main points. (I'll take any advice on this!) Cheers Mark Re: Suggestions for Media Room Setup 4May 29, 2011 9:22 pm what kind of fixed screen are you using; in doing some research (my first projector setup) there are fixed screens between $600 and $2000; Is there a major difference really between them (or is it suttle difference; big dollars)? Re: Suggestions for Media Room Setup 5May 29, 2011 9:57 pm Thanks for the info Mark. There is some difference between 400$ and 2000$ screens but however I don't think I will be able to notice the difference in a dark. . I will be buying fixed screen from http://www.ozts.com.au/ . I will be buying speaker plate from US as it's cheap -http://www.monoprice.com/home/index.asp. Re: Suggestions for Media Room Setup 7May 29, 2011 11:35 pm That's my blog http://abrahams-leneva.blogspot.com/201 ... -home.html I have a home theatre with window, they couldn't remove the window because of minimum amount of light required, I wouldn't do anything with the window, install plantation shutter. The ceiling colour has to be changed from white to light grey or something because of reflection We will be having dark carpet in HT We would be having double door. I know monoprice website is good , they have everything for cheap price Re: Suggestions for Media Room Setup 8May 30, 2011 5:51 am Some people have called us crazy but we are just about to paint our dedicated HT room a dark grey dulux colour called Namadji. Even the ceiling and skirting as well!! Very dark.lol. Main wall colour Forrester 43sq We have our keys (3/6/11) Now it's time to decorate (that's the fun part.lol) https://forum.homeone.com.au/viewtopic.php?f=31&t=37598 Re: Suggestions for Media Room Setup 9May 30, 2011 8:15 am Rudolf1980 Some people have called us crazy but we are just about to paint our dedicated HT room a dark grey dulux colour called Namadji. Even the ceiling and skirting as well!! Very dark.lol. Hi Rudolf1980 When we asked the girls at colours about having the entire HT as dark grey, they were shocked and they thought even we were crazy, but now I would be doing it after handover Re: Suggestions for Media Room Setup 12May 30, 2011 12:01 pm (posted pic of our colour above) Forrester 43sq We have our keys (3/6/11) Now it's time to decorate (that's the fun part.lol) https://forum.homeone.com.au/viewtopic.php?f=31&t=37598 Re: Suggestions for Media Room Setup 13May 30, 2011 12:11 pm Rudolf1980 Some people have called us crazy but we are just about to paint our dedicated HT room a dark grey dulux colour called Namadji. Even the ceiling and skirting as well!! Very dark.lol. Main wall colour That's the colour I want for our HT Re: Suggestions for Media Room Setup 14May 30, 2011 12:17 pm Great, its actually a exact match to our cabnet which are slat grey. I am also using this olour as feature walls throught my house. Even my bedroom. I just love it. But just think... when you go to the movies...... the darker the room, the better yeah? Its the same if you have a projector only room. Forrester 43sq We have our keys (3/6/11) Now it's time to decorate (that's the fun part.lol) https://forum.homeone.com.au/viewtopic.php?f=31&t=37598 Re: Suggestions for Media Room Setup 15May 30, 2011 1:25 pm Is anyone considering curtains on the walls as well? I've read that curtains against the walls is a good thing for sound (as opposed to just painted gyprock)? If so do you curtain the sides, rear or all or a part there of? Re: Suggestions for Media Room Setup 16May 30, 2011 2:49 pm I went a different way and went for fabric stretched over plaster. I'm very happy with the results. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Uploaded with ImageShack.us Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Uploaded with ImageShack.us My Art Deco Cinema build thread - http://www.avsforum.com/avs-vb/showthre ... t=art+deco Re: Suggestions for Media Room Setup 17May 30, 2011 8:19 pm I love it - also checked out your forum thread really impressive. Currently I've just got a 5.2x4.2 box with double door (not yet built even). I'm slowly gaining ideas on how to do the room; aside from the projector and the screen I'm still thinking. What are you using for speakers around the room (particularly the side and rear effect speakers) - I want to avoid in-wall; but I want them "on" the wall. Cheers Mark Hi, Looking to add an ensuite to one of the bedrooms and make it a Master BR. Please see the attached current floorplan. Need suggestions on what's the best way to do… 0 7354 Suggestions please for acrylic rendering Color to match austral brick urban one pepper. Pic for reference. Thanks 0 5099 ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 15234 |
