Browse Forums Home Theatre & Automation 1 May 10, 2011 11:59 pm Looking at some options for structural wiring. Internet access is the only use. Dont have Foxtel and dont have need to stream / share media. Currently have wireless but would like a wired option. Have a quote for: Study: 3 data points HT: 2 data points, 1 coax Living: 2 data points, 1 coax Family: 2 data points, 1 coax Master: 1 data points, 1 coax 3 beds: 3 data points total (1 each) All cat6. Patch panel, Clipsal harmonica Quote: $5500. This seems to be a lot more that what people have suggested eg. roughly $140 per run. How much should I be paying for this setup Re: Strutural Wiring Quote 2May 11, 2011 11:09 am I'd go a minimum of 2 points anywhere. And at least 4 for study and anywhere there's a tv. Yes, the quote is pretty rich. You should be able to do alot better. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Strutural Wiring Quote 3May 11, 2011 11:54 pm I agree that $5500 seems a bit much for what they offer. I have a quote for 20 data points, cat6 cabling and patch panel for $2200. Someone else would charge $128 per zone for data cabling + the cost for the patch panel. Either way that would be much less than what you have been quoted. You should probably get a couple of extra quotes as it looks like you are being ripped off. Thread: viewtopic.php?f=31&t=52680 SiteStart 19/11/11 Slab 10/12/11 Frame 17/02/12 Roof 3/05/12 LockUp 22/06/12 Handover 31/08/12 Re: Strutural Wiring Quote 5May 12, 2011 10:16 am Casa2 Is this for a new build (in which case it about double the price it should be) or is it for an existing build? Good point. I keep forgetting this forum is for renovators as well as new home builders! Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Re: Strutural Wiring Quote 6May 12, 2011 11:27 am Casa2 Is this for a new build (in which case it about double the price it should be) or is it for an existing build? Even for a retro fit that is way high. To the op this a brick vineer or double house? New build or retro fit? And location? Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Strutural Wiring Quote 8May 12, 2011 1:02 pm noki388 Thanks all. This will be for a new build, double brick, 2 storey home in WA. Just still is research phase and not even settled on final plan yet but wanted to get an idea if it was affordable or not. ah right additional costs for the double brick install include wall boxes, conduit, extra labour... and they are using {Coughs} bullcrap expensive clipsal **** {coughs again} could also include the wall Chasing costs which is a PITA and is labour intesive Thalian72 I agree that $5500 seems a bit much for what they offer. I have a quote for 20 data points, cat6 cabling and patch panel for $2200. Someone else would charge $128 per zone for data cabling + the cost for the patch panel. Either way that would be much less than what you have been quoted. You should probably get a couple of extra quotes as it looks like you are being ripped off. may look like noki388 is being ripped off but they havn't posted what is actually included in the full quote... and without knowing that making a judgement call on what is and what isn't a ripp off is hard to make and esp from people who like in araes that don't require the exstra work that is dealing with Double brick Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Strutural Wiring Quote 9May 12, 2011 4:30 pm Hi, Our builder was quoting $185 per data cable - & double that if we wanted 2 to the same room. I was polite & didn't express my views on what I thought of the cost. Got a life, just can't find it! Re: Strutural Wiring Quote 10May 12, 2011 4:31 pm nrh157 Hi, Our builder was quoting $185 per data cable - & double that if we wanted 2 to the same room. I was polite & didn't express my views on what I thought of the cost. umm brick vineer or double brick? Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20912 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14319 I had 28m2 of engineered pavers laid six months back and it was difficult to find someone not taking the pi$$. Internet suggested it should be $85-100/m2 to lay them.… 3 12401 |
