Browse Forums Home Theatre & Automation 1 Apr 10, 2011 9:47 am Anyone with experience here? Is cabling run outside to ground floor or other tricks used? Re: Installing foxtel sat. to dbl story 2Apr 10, 2011 10:11 am single or double cable? yes there are tricks involved.. the installer should know them all.. if not a couple... this is why one pre wires... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Installing foxtel sat. to dbl story 3Apr 19, 2011 11:37 pm ....but if you were unable to prewire then usually it means running the cables on the outside. You can usually hide the cables though under eaves and beside downpipes etc to neaten things up a little. What is the situation that you are trying to overcome? Installing foxtel sat. to dbl story 4Apr 20, 2011 7:34 am No issues. Looks like the pre-wiring was all done. Just hidden. Cheers Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8484 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4090 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6700 |
