Browse Forums Home Theatre & Automation 1 Apr 05, 2011 10:13 pm Hi all, Pls help with the correct plug in order for the following : Plasma TV, Blue Ray recorder, Foxtel, HDMI cables and surround sound amp... Currently, all is plugged seperately into the amp , then to the TV via HDMI... What I would like to do is record tv ( we use Foxtel all the time ) via the Blue Ray recorder, something that doesn't work presently. Any advice very welcome THANK YOU>>> Re: TV Component plug in order... Help a newbie 2Apr 05, 2011 11:15 pm Help is at hand! This is easy but ... 2 questions please. 1/ What inputs does the B/R recorder have? 2/ Which model foxtel box do you have (should be on the base) All we need is 3 cables - composite A/V or maybe a SCART to A/V depending on the Foxtel box. With this info I can tell you which cable you need and how to plug it in! Matt Re: TV Component plug in order... Help a newbie 3Apr 07, 2011 8:27 am Thx vmuch Matt 1. The B/R has the following inputs ( 1 year old Panasonic ) RCA plugs, Aerial, 1 HDMI and a Lan socket 2. The foxtel box model is TDS480NF Thanks for the help....Maybe I can start to use the B/R as a recorder instead of a DVD player Re: TV Component plug in order... Help a newbie 4Apr 07, 2011 8:53 am what is the model number of the panasonic? Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: TV Component plug in order... Help a newbie 5Apr 07, 2011 9:07 am Ooh .. HDMI input? Although possible that is more likely an output. AS pugs said do you have the model number? Then I could google it and look at the back of the unit online for you The good news is that you need a SCART to something cable! This is the back of your current box: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You would currently have used one of the SCART outputs (The long black things in the centre of the picture) and we will use the other to send the signal to your BR recorder! We are halfway! Cheers, Matt Re: TV Component plug in order... Help a newbie 6Apr 07, 2011 8:01 pm Hi Pugs and Matt, The Panasonic Blue Ray Burner is model DMR-BW750.. hope this helps.. Cheers Andrew Re: TV Component plug in order... Help a newbie 7Apr 07, 2011 10:41 pm Looks like composite or s-video in only http://www.pcworld.idg.com.au/review/ho ... image=1#cb Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So a scart to composite red,white & yellow I am new to this forum so please bear with me. An NCAT order was breach by our neighbour regarding a retaining wall dispute. He is the owner of a building company and he… 0 2221 a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8871 Hi there, long-time lurker but first time posting. I've bought a house 2 and a bit years ago and last year we had some major water damage on a converted pergola area… 0 8002 |
