Browse Forums Home Theatre & Automation Re: Advice for newbie 2Apr 04, 2011 9:13 am Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Advice for newbie 5Apr 12, 2011 9:31 am Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Advice for newbie 7Apr 13, 2011 9:17 am If you really wanted to have the projector and screen movable from inside to out and back this is not really that difficult to set up. Here's how I would do it: 1. For the projector, get 2 of the same bracket - eg. this one: http://www.selbyacoustics.com.au/storef ... =150703466 ... where you can detach the bottom half of the bracket - the half that is permanently attached to the projector itself, and move that between two permanently mounted top halfs (one inside and one outside). Re-zooming and focussing will be a snap. You'd obviously need/want all of the cabling installed in both locations also. 2. For the screen you could have a manual pull-down or a motorised one. It would want to come with a pretty quick mounting method (eg. maybe something as simple as a couple of loops for a pair of mounted hooks in each location?). For a motorised you would need a power-point in each location, and it really should have RF control - that way there shouldn't be any cable and receiver to worry about (like it would have if it was IR control). Not for the lazy, but possible... a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8718 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17355 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13830 |
