Browse Forums Home Theatre & Automation 1 Apr 03, 2011 9:14 am I hope someone can help me with the best positionning of power outlets and aerial plug for my TV and DVD player etc. At present we have a wall cavity which has been created by having a jetmaster open fire place. It is 3.8 m long and around 600mm deep, the fireplace is at one end and the other end is for the TV. We are planning on hanging the TV flat on this wall with a built in cabinet underneath. We have an amplifier, 2 DVD players, wii and playstation and may have a stereo if I can work out how to set it up! The electrician has already placed speaker wire in the ceilling What would be the best place for the power? Behind the TV or down in the cabinet? The cabinet space is large, we have left a space of around 1400w by 700h. Is there anything else that would help with this set up? I am not very savvy with electronics and would like to have it all done correctly when I can and not regret later. thank you in advance Re: help with where to place power outlets and aerial 2Apr 03, 2011 9:42 am leanne27 I hope someone can help me with the best positionning of power outlets and aerial plug for my TV and DVD player etc. At present we have a wall cavity which has been created by having a jetmaster open fire place. It is 3.8 m long and around 600mm deep, the fireplace is at one end and the other end is for the TV. We are planning on hanging the TV flat on this wall with a built in cabinet underneath. We have an amplifier, 2 DVD players, wii and playstation and may have a stereo if I can work out how to set it up! The electrician has already placed speaker wire in the ceilling What would be the best place for the power? Behind the TV or down in the cabinet? The cabinet space is large, we have left a space of around 1400w by 700h. Is there anything else that would help with this set up? I am not very savvy with electronics and would like to have it all done correctly when I can and not regret later. thank you in advance IN wall signal cabling.. HDMI/ Network/ power to the TV Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: help with where to place power outlets and aerial 4Apr 03, 2011 7:34 pm leanne27 Another stupid question, how does one access the points behind the wall? generally you have a "master source" that handles all of the switching of "cables" instead of dismounting the TV every time. then you only have Power, FTA, HDMI and maybe a Network cable (if you tv has that) and then you don't have to touch the TV any time after you install it Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Our relationship with the owner is good, but I'm not sure if I want to impose putting a pole on their property. Your conversation with your neighbour must have gone well… 4 9318 Use a product like Equisol's Vitalise to clean the deck then coat with a penetrating timber oil. It will look 10 years younger and add value to your home. Visit for… 1 15795 |
