Browse Forums Home Theatre & Automation Re: Are all TV Brackets created equal? 2Mar 29, 2011 1:05 pm The cheap ones generally are as good as the expensive ones made by the TV brands themselves. Basically it just needs to be VESA compatible and be solid. Other than that you should speak to the people selling them - I know TCC and Selby are happy to discuss this stuff with customers. Re: Are all TV Brackets created equal? 4Mar 29, 2011 3:21 pm Thanks Rodda, was interesting to me also. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Are all TV Brackets created equal? 5Mar 30, 2011 8:18 am I have a Soniq bracket holding up a 42" LCD. It is great and I was extremely impressed with how all the bits and pieces were packaged in the box. It was extremely clear. Follow our journey at http://www.notgoingtodreamworld.blogspot.com Our build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=48999 Re: Are all TV Brackets created equal? 6Mar 30, 2011 10:15 am I have these brackets and they are every bit as good the the expensive ones http://www.thecableconnection.com.au/32 ... 78E6A.html I am putting together a deal for homeone members at the moment ... if you need some of this gear hold off for a few days. Re: Are all TV Brackets created equal? 7Mar 30, 2011 10:55 am I got a selby one off ebay, great price, free postage and very good product... I think someone on here reccommended it or has something to do with the company Selby itself..can't remember. But highly reccomend one. We have only bought one for now for our 50" TV, but will be buying another for our 42" TV. Heavy TV's and no problems at all The road to success is always under construction House completed April 2011 - slowly making it a home... Re: Are all TV Brackets created equal? 8Mar 31, 2011 8:54 pm just shop around for the good deal ... There is nothing special about Selby brackets, i.e. they are not "Selby" bracket, they are the brackets that Selby re-sell. I used to buy some from them, but last time I check the price, it went up nearly 30% in no time. I ended buying from different supplier and found that I bought the same brand of bracket at cheaper price. [url]ACMA registered cable, Government endorsed Antenna Installer[/url] Re: Are all TV Brackets created equal? 9Apr 01, 2011 1:39 pm IQtech just shop around for the good deal ... There is nothing special about Selby brackets, i.e. they are not "Selby" bracket, they are the brackets that Selby re-sell. I used to buy some from them, but last time I check the price, it went up nearly 30% in no time. I ended buying from different supplier and found that I bought the same brand of bracket at cheaper price. IQTech, You are right there are some great deals around ... you just need to know where to look... Re: Are all TV Brackets created equal? 10Apr 01, 2011 2:27 pm Is it essential to reinforce the wall prior to plastering stage? Or will a bracket do all the reinforcing that is required? What should one do (if anything) prior to plastering, to ensure the TV is secure on the wall? Re: Are all TV Brackets created equal? 11Apr 01, 2011 2:53 pm Make sure you screw that sucker into a stud or noggin. It's probably wise to ad some extra braces before plaster if you can. I didn't, so now i've just gotta hope the height I want coincides with where the noggin is. Unfortunately the 65" telly I want isn't going to hang off fresh air. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Are all TV Brackets created equal? 12Apr 01, 2011 3:19 pm @rockabilly_kid. On a 65" TV you are likely to cover 3 stud widths even at 600mm centres. There is absolutely NO CHANCE of not hitting a stud in your case. This is also true of most TV's down to about 37" in size. Re: Are all TV Brackets created equal? 13Apr 01, 2011 3:33 pm Hahaha, that's a good point Matt! This is a case of me thinking ahead without thinking at all. Happens a bit. Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Are all TV Brackets created equal? 14Apr 01, 2011 5:52 pm What would be an ideal height to put the extra bracing? Assuming that it's an average size room and 2.7m ceiling? Re: Are all TV Brackets created equal? 15Apr 04, 2011 9:24 am Depends where you want the TV, and that all depends on where you find it most comfortable! Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Are all TV Brackets created equal? 16Apr 05, 2011 2:57 pm Even a 65" screen is not as heavy as you think, especially now that they are making them thinner and lighter than ever. So even for a screen that big, as long as you get good purchase on at least 2 studs (eg. 2 very decent (likely hex-head) screws minumim per stud) there is no need for any 'extra' bracing to be installed prior to plaster going up. It would take a lot more force than the weight of a 65" flat TV to pull those studs through the plaster or pull those decent screws out of the timber... Re: Are all TV Brackets created equal? 17Apr 05, 2011 3:19 pm Do you have a recommendation on the screw specs for that kinda job, Rodda? Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Are all TV Brackets created equal? 18Apr 05, 2011 4:21 pm Hi mate. I'd say anything approaching but not longer than 90mm (so including the plaster will stop short before going through the other side of the stud) and with a centre/core at least 4mm I guess. As an example The Cable Connection's brackets come with a small collection of bolts and washers and with 6 very decent hex-head screws that are these sorts of dimensions from memory... Re: Are all TV Brackets created equal? 19Apr 05, 2011 4:30 pm Thanks for the info yet again! Homestead Homes SA: The Lamont Bayswood Estate; Aldinga Beach Preliminary Signing: April 2010 Floorplans: 13 June 2010 Building Contract: 19 June 2010 Selections: 28 Sept 2010 Scraped; Trenching: 21 Jan 2011 Slab Poured: 28 Jan 2011 Framing: 17 Feb 2011 | Completed 24 Feb 2011 Roof & Gutters: 02 Mar 2011 Bricks: 03 Mar 2011 Wire-up: 12 Mar 2011 Re: Are all TV Brackets created equal? 20Apr 08, 2011 9:19 am Hi Matt, Anything Special happening today Site Start: 10th September, 2010 PCI : Friday 27th January, 2011. Handover: 3rd February, 2011 Build Thread: viewtopic.php?f=31&t=37677 Old Home Restoration / Renovation Cheers mate! This is exactly what I was thinking but wasn't sure if it was something I'd find on the shelf. I agree with you, fixing the brackets to the board will look… 2 3283 Building Standards; Getting It Right! When my house was built (over 7 years ago), the post brackets were done to allow for concrete porch, but they didn’t allow for the planned stone paving. I’m finally… 0 1920 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 5811 |
