Browse Forums Home Theatre & Automation 1 Mar 15, 2011 9:20 pm In the process of getting some quotes for some pre-wiring and while we've opted for 50 mm conduit for the projector, an installation company suggested we also put the power through the conduit instead of an SGPO in the ceiling. Pro's are that its easier to switch off at the base of the wall (where the other end of the conduit is) and one can probably put the projector power onto surge protection. Cons - ??? Is it okay to have 240V power cable in the conduit with HDMI/HDMI over Cat6 ? Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 2Mar 15, 2011 11:50 pm not ok.. they should know better Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 4Mar 16, 2011 4:13 pm jklow888 Pugs not ok.. they should know better So stick to the SGPO on the ceiling and just have HDMI/HDMI over Cat6 in conduit ? Yes Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 5Mar 17, 2011 2:50 pm Pugs = the expert on all things ethernet! Good advice! Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 6Mar 17, 2011 7:24 pm Pugs not ok.. they should know better Should the 240V run be on the one side of the joist and the conduit on the other side at the width of the joist ? Whats the min space required between the 2 ? Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 7Mar 17, 2011 7:37 pm I think 50mm is the minimum but Pugs will confirm that. A stud width would be a good start!! Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 8Mar 17, 2011 7:45 pm jklow888 Pugs not ok.. they should know better Should the 240V run be on the one side of the joist and the conduit on the other side at the width of the joist ? Whats the min space required between the 2 ? that is enough seperation but hey if they don't know what they are doing then they shouldn't be doing the job... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 10Mar 17, 2011 9:25 pm Pugs that is enough seperation but hey if they don't know what they are doing then they shouldn't be doing the job... Thanks - I think the job is too small for most of the home theater installers so they either don't want the job or are over quoting. All I need is 4 pairs of Cat 6 to be run, 6 pairs of audio cable to be run and each end terminated to wall plates (2/4 port for Cat 6 and 8/8 pair plates to 2 pairs of surround speakers. In the worst case, I'll have to get the builders electrician to do this and make sure its done to the correct separation and terminate the ends myself. Anyone in Sydney who's a licensed cabler who's interested in a "small job" ? Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 11Mar 17, 2011 9:32 pm E1109 Best reference for this is AS 3000:2007 clause 7.5 in regards to separation from low and extra-low voltage wiring. Can't find this doc online/looks like a "paid for doc" (which I find strange). Can you confirm what is the min separation distance - would be nice for my own reference simply to check that the electrician and cabler aren't running next to each other when I do get to checking out the wiring. Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 12Mar 18, 2011 5:22 pm jklow888 E1109 Best reference for this is AS 3000:2007 clause 7.5 in regards to separation from low and extra-low voltage wiring. Can't find this doc online/looks like a "paid for doc" (which I find strange). Can you confirm what is the min separation distance - would be nice for my own reference simply to check that the electrician and cabler aren't running next to each other when I do get to checking out the wiring. Yep, you have to pay to download it from the SAI Global website. I'll check at work tomorrow for you, its beer o'clock here in Darwin Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 13Mar 18, 2011 9:38 pm Hi, There is some information about separation in the AS/ACIF S009 wiring rules on page 56, section 16.3. In summary, the services can be separated by
To answer your original question, you could run the 240V in the same conduit as the Cat6, but you would need to sub-duct the 240V inside another conduit (orange) inserted inside the white communications conduit (this in accordance with section 16.3.3 of S009), but it wouldn't make sense to go to this expense when you can just run the 240V cable on the other side of the joist Paul Re: 240V cable and HDMI/HDMI over CAT6 together in conduit O 14Mar 18, 2011 9:56 pm if you want them at the same spot then just use two conduits.. that is how they wire your phone line from the street, it sits side by side with the electrical conduit in most cases. the conduit would need to be undamaged regardless of what network is in play. The conduit needs to be able to have fibre run through it. NBN and Opticomm are just… 4 2876 If there have been changes, variations, during construction then the drawings should be revised, the building permit amended and the current, as built drawings given to… 2 4445 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 |
