Browse Forums Home Theatre & Automation 1 Mar 09, 2011 11:40 am Hi all, does everyone have a dark ceiling colour for their home theater? It is obviously ideal to have it a darker colour other than white, but does every one's home theater room have a darker ceiling or if not, how have you found the white ceiling effect projector image? And what colour is it other than white? Any photos? I initially have put in to have a dark plum colour on our theater walls and now have the last chance or opportunity to change the ceiling from white if I decide... thanks Builder: Dennis Family Homes House: Hartley Facade: Provincial Suburb: Lyndhurst Moved in! http://cynash.blogspot.com Re: Ceiling colour? 2Mar 09, 2011 12:38 pm A dark ceiling is good, as a white ceiling will reflect the ambient light in the room plus some of the light bouncing of things like the screen (ie. the projected light), and reducing the amount of outside interference (like this light we talk of) hitting the image on the screen is always going to help get the best picture you can, however, today's projectors are brighter and have better contrast than they used to so if you really don't want to go to those lengths with the paint you will still get a fantastic picture from a projector/screen in a room with a white ceiling. I have installed many home cinemas in rooms with dark ceilings, but I have installed even more in rooms with white ceilings - all looked good Re: Ceiling colour? 3Mar 17, 2011 2:45 pm I personally think a darker ceiling is better. Having had both I would always go with a dark ceiling but... ...it depends on the room. If it was a multi use room (ie a lounge room that was sometimes used to watch movies) I would go with white but if it was a room that was mainly used for movies and the like then a dark ceiling is a must! Unless the room is for storage then it's non compliant BCA V2 2019 S3 P3.8 You have 2 options 1. The builder deconstructs the section and rebuilds as per plan /… 7 10665 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5907 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2447 |
