Browse Forums Home Theatre & Automation 1 Dec 14, 2007 7:19 pm Matt,
I've just taken a look at your blog and your home theatre in particular. You've undoubtedly been asked these questions before and there's probably an answer somewhere in this forum, but I'll ask anyway. 1) What is the size of your home theatre room? 2) If you had a magic wand, what size room would you change it to? 3) What is the size of the rasied floor section at the rear (height and depth)? 4) What is the thing at the rear of the room that looks like a screen? Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Matt, some questions about your home theatre 2Dec 18, 2007 12:29 pm ![]() Matt, I've just taken a look at your blog and your home theatre in particular. You've undoubtedly been asked these questions before and there's probably an answer somewhere in this forum, but I'll ask anyway. ![]() 1) What is the size of your home theatre room? 7 metres deep x 4 metres wide ![]() 2) If you had a magic wand, what size room would you change it to? 8 metres deep x 5 metres wide ![]() 3) What is the size of the rasied floor section at the rear (height and depth)? 4 metres wide x 1.5 metres deep x 200mm high ![]() 4) What is the thing at the rear of the room that looks like a screen? Its the roller blind inside the window and the roman blind is above that! Cheers, Casa Re: Matt, some questions about your home theatre 4Dec 19, 2007 10:49 pm Matt,
Took another look at your blog (congratulations on over 10,000 hits!). Your home theatre looks better the more pictures I see. If your screen wall is 4 meters wide then that would make your screen, if my calculations are correct, 135". That's one large screen. Is it 135"? Do they come any bigger for domestic use? Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Matt, some questions about your home theatre 5Dec 20, 2007 11:23 am ![]() Matt, Took another look at your blog (congratulations on over 10,000 hits!). Your home theatre looks better the more pictures I see. If your screen wall is 4 meters wide then that would make your screen, if my calculations are correct, 135". That's one large screen. Is it 135"? Do they come any bigger for domestic use? Cheers, Casa Casa, Well worked out! It is 135"!! The screen size can be made as big as you like. The only sticking point is $$$ generally... Re: Matt, some questions about your home theatre 6Dec 20, 2007 12:16 pm ![]() The screen size can be made as big as you like. The only sticking point is $$$ generally... And the size of your wall ![]() ![]() ![]() Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Matt, some questions about your home theatre 7Dec 20, 2007 12:51 pm Re: Matt, some questions about your home theatre 8Dec 21, 2007 8:48 am Matt,
I've noticed that you've broken from "conventional wisdom" and do not have an LCD TV as well as the projection system. Does this mean that the Theatre room is only used for the occasional movies? I like the idea of using the Theatre room for everyday watching of TV and would be interested in how you've set up your room and what you think. I also like the idea of using just a projection system, but as already mentioned elsewhere, I would have to consider the running costs considering the relatively short life of the projector bulbs and their high cost. Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Matt, some questions about your home theatre 10Dec 27, 2007 10:37 am Hi Kiwi.
I'll let Matt answer for himself but I need to chuck my own 2 cents worth in here... I f**king love them! They K.F.A. Don't get me wrong, I love my Elan MP800W In-wall fronts as well - they are exceptionally nice for In-walls, but Matt's Paradigm Monitor 11 floorstanders are something else again!! (the CC-390 centre ain't half bad either). Re: Matt, some questions about your home theatre 11Dec 27, 2007 10:42 am ![]() I f**king love them! They K.F.A. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I bet ALL the Thursday "boy's" night's are now at Matt's place as a result.... ![]() ![]() ![]() ![]() Re: Matt, some questions about your home theatre 12Dec 27, 2007 1:02 pm ![]() Hi Kiwi. I'll let Matt answer for himself but I need to chuck my own 2 cents worth in here... I f**king love them! They K.F.A. Don't get me wrong, I love my Elan MP800W In-wall fronts as well - they are exceptionally nice for In-walls, but Matt's Paradigm Monitor 11 floorstanders are something else again!! (the CC-390 centre ain't half bad either). Thanks Rodda, I was concerned with the mains being in the corners and the centre being on the floor the sound would be somewhat muffled. Certainly looks a nice homely room to sit back and enjoy a few brews, and the odd movie. Old Home Restoration / Renovation Hi All, I am planning to convert my theatre room to 4th bed, is it worth or can we do it with the plan I have attached Thanks for taking your time Regards, Harry 0 1675 6 5974 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 8100 |
